[Qgis-community-team] gui translation messages without source location in ts files
Lauri Kajan lauri.kajan at gmail.com
Thu Mar 7 02:45:15 PST 2013
Thanks Werner.
This explains everything.
-Lauri
On Thu, Mar 7, 2013 at 12:40 PM, Werner Macho <werner.macho at gmail.com>wrote:
> Hi!
> Ah ok I see .. yes as it says these are "obsolete" strings - but they are
> still there to give some suggestion if similar strings appear again and
> help you with translating. It's nothing to worry about. They can also be
> cleaned out if you want .. but than you will not get any translation
> suggestions any more from linguist.
> hope that helps
> kind regards
> Werner
> On Thu, Mar 7, 2013 at 11:25 AM, Lauri Kajan <lauri.kajan at gmail.com>wrote:
>> Hi Werner,
>> Most translatable string are defined in qgis_*.ts files as following:
>>     <message>
>>         <location filename="../src/gui/qgsmanageconnectionsdialog.cpp"
>> line="84"/>
>>         <source>Save connections</source>
>>         <translation>Tallenna yhteydet</translation>
>>     </message>
>> But then there are also strings that don't have that location tag in it.
>>     <message>
>>         <source>Load from file</source>
>>         <translation type="obsolete">Lataa tiedostosta</translation>
>>     </message>
>> And these strings are disabled (grayed) in QtLinquist and can not be
>> translated/modified.
>> Are these some old translation strings? Or should I also translate those?
>> -Lauri
>> On Thu, Mar 7, 2013 at 12:15 PM, Werner Macho <werner.macho at gmail.com>wrote:
>>> Hi!
>>> I don't know exactly what you mean - can you explain it a bit further -
>>> and what problems you have?
>>> kind regards
>>> Werner
>>> On Thu, Mar 7, 2013 at 10:45 AM, Lauri Kajan <lauri.kajan at gmail.com>wrote:
>>>> Hi all,
>>>> May I ask what are those <message>s in ts files without any source
>>>> location?
>>>> Those are disabled in QtLinguist.
>>>> -Lauri
>>>> _______________________________________________
>>>> Qgis-community-team mailing list
>>>> Qgis-community-team at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130307/e0ab2d36/attachment.html>
More information about the Qgis-community-team mailing list
