[Qgis-community-team] Transifex project created
Marie Silvestre marie_silvestre at yahoo.fr
Sun Mar 17 08:19:14 PDT 2013
Which version of the documentation is on transifex (it really sounds like some medicine..)?
It looks like it comes directly from the i18n/en/ directory in github and it is not up to date with the rst files. An example with qgis_gui :
The first string in the corresponding rst file [1] is :
"When QGIS starts, you are presented with the GUI as shown below
(the numbers 1 through 5 in yellow ovals refer to the six major areas of the
interface as discussed below):"
whereas in transifex and in en/.../qgis_gui.po [2]  it's :
"When QGIS starts, you are presented with the GUI as shown below (the
numbers 1 through 7 in yellow ovals refer to the six major areas of the
[1] https://github.com/qgis/QGIS-Documentation/blob/manual_en_v1.8/source/docs/user_manual/introduction/qgis_gui.rst
[2]https://github.com/qgis/QGIS-Documentation/blob/manual_en_v1.8/i18n/en/LC_MESSAGES/docs/user_manual/introduction/qgis_gui.po#L33
Appart from that it looks fully functional and featured!
Translators have already subscribed to the french team!
Marie
 De : Tim Sutton <lists at linfiniti.com>
À : Marie Silvestre <marie_silvestre at yahoo.fr>
Cc : qgis-community <qgis-community-team at lists.osgeo.org>
Envoyé le : Samedi 16 mars 2013 21h26
Objet : Re: [Qgis-community-team] Transifex project created
Hi
On Sat, Mar 16, 2013 at 1:09 PM, Marie Silvestre
<marie_silvestre at yahoo.fr> wrote:
> Hi Tim,
> I would like to crash test transifex for the french team!
> My transifex username is "MarieSilvestre". I've just requested a french team
> (don't know if it's the right procedure though..).
Perfect - I accepted your request and others like it.You should be
able to start translating directly on the site or upload your local po
files for each resource if you have them. This is actually what I
recommend you do first - simply upload your po files using the
provided UI in transifex and then when all existing work is synced
encourage your translators to start translating.
By the way I didnt exactly mirror the on-disk heirarchy of po files in
the resource names (in transifex its a flat list with no hierarchy) so
I used some basic naming conventions. If these conventions dont sit
well with you all, its a good time to say so before work starts in
earnest.
@Anibal its probably simplest if you just go to the project page and
register as a translator for your chosen locale as others have done.
Regards
Tim
> Regards,
> Marie
> À : qgis-community <qgis-community-team at lists.osgeo.org>
> Envoyé le : Samedi 16 mars 2013 0h30
> Objet : [Qgis-community-team] Transifex project created
> Hi All
> I have created a transifex project here:
> https://www.transifex.com/projects/p/qgis-documentation/
> The project contains all translatable resources from the
> QGIS-Documentation repo. Now is the time to create languages and
> noinate team leaders for each language.
> If you are interested in working / testing the Transfex environment as
> a language maintainer, pop me an email with your transifex username
> and I will grant you the needed privileges. There after you should be
> able to allow your team members to add themselves.
> Regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Skype: timlinux
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130317/b5671b88/attachment.html>
More information about the Qgis-community-team mailing list
