[Qgis-community-team] Transifex project created
Tim Sutton tim at linfiniti.com
Sun Mar 17 13:13:06 PDT 2013
Hi
On Sun, Mar 17, 2013 at 5:19 PM, Marie Silvestre
<marie_silvestre at yahoo.fr>wrote:
> Which version of the documentation is on transifex (it really sounds like
> some medicine..)?
> It looks like it comes directly from the i18n/en/ directory in github and
> it is not up to date with the rst files. An example with qgis_gui :
> The first string in the corresponding rst file [1] is :
> "When QGIS starts, you are presented with the GUI as shown below (the
> numbers 1 through 5 in yellow ovals refer to the six major areas of the
> interface as discussed below):"
> whereas in transifex and in en/.../qgis_gui.po [2]  it's :
> numbers 1 through 7 in yellow ovals refer to the six major areas of the
> [1]
> https://github.com/qgis/QGIS-Documentation/blob/manual_en_v1.8/source/docs/user_manual/introduction/qgis_gui.rst
> [2]
> https://github.com/qgis/QGIS-Documentation/blob/manual_en_v1.8/i18n/en/LC_MESSAGES/docs/user_manual/introduction/qgis_gui.po
> #L33
Ok this is because the docs I have pushed are for master not 1.8. I will
look to the translators for guidance as to what should appear in transifex
(1.8 or master).  Also bear in mind that I ams still new to transifex
myself so I don't have complete understanding yet of how we should manage
multiple versions in the source at the same time.
Regards
Tim
>  Appart from that it looks fully functional and featured!
> Translators have already subscribed to the french team!
> Marie
> *De :* Tim Sutton <lists at linfiniti.com>
> *À :* Marie Silvestre <marie_silvestre at yahoo.fr>
> *Cc :* qgis-community <qgis-community-team at lists.osgeo.org>
> *Envoyé le :* Samedi 16 mars 2013 21h26
> *Objet :* Re: [Qgis-community-team] Transifex project created
> Hi
> On Sat, Mar 16, 2013 at 1:09 PM, Marie Silvestre
> <marie_silvestre at yahoo.fr> wrote:
> > Hi Tim,
> > I would like to crash test transifex for the french team!
> > My transifex username is "MarieSilvestre". I've just requested a french
> team
> > (don't know if it's the right procedure though..).
> Perfect - I accepted your request and others like it.You should be
> able to start translating directly on the site or upload your local po
> files for each resource if you have them. This is actually what I
> recommend you do first - simply upload your po files using the
> provided UI in transifex and then when all existing work is synced
> encourage your translators to start translating.
> By the way I didnt exactly mirror the on-disk heirarchy of po files in
> the resource names (in transifex its a flat list with no hierarchy) so
> I used some basic naming conventions. If these conventions dont sit
> well with you all, its a good time to say so before work starts in
> earnest.
> @Anibal its probably simplest if you just go to the project page and
> register as a translator for your chosen locale as others have done.
> Regards
> Tim
> > Regards,
> > Marie
> > ________________________________
> > De : Tim Sutton <lists at linfiniti.com>
> > À : qgis-community <qgis-community-team at lists.osgeo.org>
> > Envoyé le : Samedi 16 mars 2013 0h30
> > Objet : [Qgis-community-team] Transifex project created
> > Hi All
> > I have created a transifex project here:
> > https://www.transifex.com/projects/p/qgis-documentation/
> > The project contains all translatable resources from the
> > QGIS-Documentation repo. Now is the time to create languages and
> > noinate team leaders for each language.
> > If you are interested in working / testing the Transfex environment as
> > a language maintainer, pop me an email with your transifex username
> > and I will grant you the needed privileges. There after you should be
> > able to allow your team members to add themselves.
> > Regards
> > Tim
> > Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> > Please do not email me off-list with technical
> > support questions. Using the lists will gain
> > more exposure for your issues and the knowledge
> > surrounding your issue will be shared with all.
> > Visit http://linfiniti.com to find out about:
> > * QGIS programming and support services
> > * Mapserver and PostGIS based hosting plans
> > * FOSS Consulting Services
> > Skype: timlinux
> > Irc: timlinux on #qgis at freenode.net
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Skype: timlinux
 * QGIS programming services
 * GeoDjango web development
Skype: timlinux Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130317/f65c565f/attachment.html>
More information about the Qgis-community-team mailing list
