[Qgis-community-team] Transifex updates
Tim Sutton tim at linfiniti.com
Wed Mar 20 00:37:09 PDT 2013
Hi Werner
On Wed, Mar 20, 2013 at 9:31 AM, Werner Macho <werner.macho at gmail.com>wrote:
> Hi Tim!
> As I already wrote I have tried transifex 2 years ago but it was hard to
> integrate into .ts/linguist .. probably that has changed now.
> I already have created a QGIS Project (also 2 years ago) to not loosing
> the name ..
> Probably we can reactivate that now and let the GUI translation run over
> it?
> But there is still the question howto integrate it with linguist/.ts
> files..
> Yes I have it working with ts files in InaSAFE - could you make me a
project admin on QGIS project in transifex?
Thanks
Tim
> Unfortunately I am still in bed - but any request for taking the account
> will be proved ;)
> kind regards
> Werner
> On Wed, Mar 20, 2013 at 7:41 AM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi All
>> Unless there are other pending issues, I think I am pretty much
>> finished configuring and understanding transifex for the
>> QGIS-Documentation repo. Here is the current status:
>> * The transifex project reflects documentation for v1.8 of the manual
>> * Last night I pushed all existing translations up to the project so
>> it should reflect the current translation state of each language.
>> Please take a look at your language and see if this is indeed the
>> case.
>> * I've written a script to automate the process of pushing language
>> files - this is available under scripts/create-transifex-resources.sh
>> and is backported to both 1.8 and master branches.
>> * To 'download' translation updates to the git repository Otto or
>> other git committers should follow this procedure:
>> Things that only need to be done once:
>> sudo pip install transifex-client
>> cd /tmp
>> tx init
>> Take the defaults and enter your password when prompted. Note that you
>> password is stored in clear text in ~/.transifexrc
>> Now go to your local QGIS-Documentation repo and do this everytime you
>> want to fetch updates:
>> tx pull
>> git status
>> git add [any new language files)
>> git commit -m "Updated i18n resources from Transifex" i18n
>> To push any local changes to transifex (for example if you did
>> translation work locally using QtLinguist):
>> I would greatly appreciate if someone could test the above procedures
>> and then transpose the information above into the README.rst file in
>> the base of the documentation tree.
>> I am now going to go on and do the same for the QGIS Training manual
>> and the QGIS application itself.
>> Best regards
>> Tim
>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>>  * QGIS programming and support services
>>  * Mapserver and PostGIS based hosting plans
>>  * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
>> Qgis-community-team mailing list
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
 * QGIS programming services
 * GeoDjango web development
Skype: timlinux Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130320/9b27eb48/attachment-0001.html>
More information about the Qgis-community-team mailing list
