[Qgis-community-team] user manual 2.0 good news
Werner Macho werner.macho at gmail.com
Mon Nov 4 08:05:42 PST 2013
Hi!
There is a good description in the Readme at
https://github.com/qgis/QGIS-Website
Hope this helps
regards
Werner
On Mon, Nov 4, 2013 at 6:01 PM, Alexandre Neto <senhor.neto at gmail.com> wrote:
> No dia 4 de Nov de 2013 10:07, "Otto Dassau" <dassau at gbd-consult.de>
> escreveu:
>> Hi,
>> yes it works. I added it to conf.py and I use make html / make pdf with a
>> virtualenv.
> thats probably my problem. I am seeing that my changes to conf.py did not
> aply to my make pdf. how can i set the virtual enviorment?
> thanks!
>> Regards
>> Otto
>> Am Fri, 1 Nov 2013 14:08:44 +0000
>> schrieb Alexandre Neto <senhor.neto at gmail.com>:
>> > Hello,
>> > Otto, did the :width: 1.3em worked? I have tried several times and with
>> > no
>> > success. I was using the pos_translate.sh.
>> > Regards,
>> > Alexandre
>> > On Fri, Nov 1, 2013 at 9:33 AM, Richard Duivenvoorde
>> > <richard at duif.net>wrote:
>> > > On 01-11-13 08:54, Otto Dassau wrote:
>> > > > Hi Alexandre,
>> > > > I also went through the pdf again, fixed some links, shortened lines
>> > > > to
>> > > fit
>> > > > on the page and defined the checkbox size.
>> > > > Thanks for taking care about the figure size and I agree that we
>> > > > should
>> > > focus
>> > > > on the pdf.
>> > > If you make changes and want to know how it currently looks, give me a
>> > > call, and I will start the build for you
>> > > Regards,
>> > > Richard
>> Qgis-community-team mailing list for organizing community resources such
>> as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Qgis-community-team mailing list for organizing community resources such as
More information about the Qgis-community-team mailing list
