[Qgis-community-team] user manual 2.0 good news
Alexandre Neto senhor.neto at gmail.com
Mon Nov 4 09:23:25 PST 2013
thanks!
Alexandre Neto
No dia 4 de Nov de 2013 16:05, "Werner Macho" <werner.macho at gmail.com>
escreveu:
> Hi!
> There is a good description in the Readme at
> https://github.com/qgis/QGIS-Website
> Hope this helps
> regards
> Werner
> On Mon, Nov 4, 2013 at 6:01 PM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
> > No dia 4 de Nov de 2013 10:07, "Otto Dassau" <dassau at gbd-consult.de>
> > escreveu:
> >> Hi,
> >> yes it works. I added it to conf.py and I use make html / make pdf with
> a
> >> virtualenv.
> > thats probably my problem. I am seeing that my changes to conf.py did not
> > aply to my make pdf. how can i set the virtual enviorment?
> > thanks!
> >> Regards
> >> Otto
> >> Am Fri, 1 Nov 2013 14:08:44 +0000
> >> schrieb Alexandre Neto <senhor.neto at gmail.com>:
> >> > Hello,
> >> > Otto, did the :width: 1.3em worked? I have tried several times and
> with
> >> > no
> >> > success. I was using the pos_translate.sh.
> >> > Regards,
> >> > Alexandre
> >> > On Fri, Nov 1, 2013 at 9:33 AM, Richard Duivenvoorde
> >> > <richard at duif.net>wrote:
> >> > > On 01-11-13 08:54, Otto Dassau wrote:
> >> > > > Hi Alexandre,
> >> > > > I also went through the pdf again, fixed some links, shortened
> lines
> >> > > > to
> >> > > fit
> >> > > > on the page and defined the checkbox size.
> >> > > > Thanks for taking care about the figure size and I agree that we
> >> > > > should
> >> > > focus
> >> > > > on the pdf.
> >> > > If you make changes and want to know how it currently looks, give
> me a
> >> > > call, and I will start the build for you
> >> > > Regards,
> >> > > Richard
> >> _______________________________________________
> >> Qgis-community-team mailing list for organizing community resources such
> >> as documentation, translation etc..
> >> Qgis-community-team at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> as
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20131104/de73652c/attachment-0001.html>
More information about the Qgis-community-team mailing list
