[Qgis-community-team] user manual 2.0 good news
Otto Dassau dassau at gbd-consult.de
Tue Nov 5 03:16:04 PST 2013
what about "releasing" the current manual as QGIS 2.0 and branch for
translation? I think we should not wait any longer. I fixed/changed some
more things / figure sizes for the pdf and I think it looks ok.
We could try to improve the figures for the next version.
What do yo think? Richard, would it be ok for you to create translation
branch for 2.0 and prepare it for transifex, etc?
Regards,
Otto
Am Mon, 4 Nov 2013 11:06:55 +0100
schrieb Otto Dassau <dassau at gbd-consult.de>:
> Hi,
> yes it works. I added it to conf.py and I use make html / make pdf with a
> virtualenv.
> Regards
> Otto
> Am Fri, 1 Nov 2013 14:08:44 +0000
> schrieb Alexandre Neto <senhor.neto at gmail.com>:
> > Hello,
> > Otto, did the :width: 1.3em worked? I have tried several times and with
> > no success. I was using the pos_translate.sh.
> > Regards,
> > Alexandre
> > On Fri, Nov 1, 2013 at 9:33 AM, Richard Duivenvoorde
> > <richard at duif.net>wrote:
> > > On 01-11-13 08:54, Otto Dassau wrote:
> > > > Hi Alexandre,
> > > > I also went through the pdf again, fixed some links, shortened lines
> > > > to
> > > fit
> > > > on the page and defined the checkbox size.
> > > > Thanks for taking care about the figure size and I agree that we
> > > > should
> > > focus
> > > > on the pdf.
> > > If you make changes and want to know how it currently looks, give me a
> > > call, and I will start the build for you
> > > Regards,
> > > Richard
More information about the Qgis-community-team mailing list
