[Qgis-community-team] Transifex and old translations
Werner Macho werner.macho at gmail.com
Fri Nov 22 03:54:13 PST 2013
Uhmmm ..
Bad .. thats very bad ..
But IIRC that was one of the reasons I initially skipped using
transifex for the GUI (because the GUI is just too important)
Hope we will find a solution so that we can switch GUI translation too ..
kind regards
Werner
On Fri, Nov 22, 2013 at 12:12 PM, Alexander Bruy
<alexander.bruy at gmail.com> wrote:
> Hi all,
> I just found very annoying issue that (I suspect) caused by Transifex.
> After downloading .po files from Transifex (no matter via web interface or
> using tx client) all old translations are empty.
> So if I translated some text and then later original text and .po file will
> updated, my previous translation doesn't keep. E.g. initially we have text
> "When starting QGIS for the first time not all core plugins are loaded."
> and I translated it and pushed this translation to Transifex. After this text
> updated to
> "When starting |qg| for the first time not all core plugins are loaded."
> and all translations also updated. When I download updated file I can
> see previous version of this string but with empty translation. And as result
> I should translate this string again from scratch.
> Is it me or this issue really exists? If this is not my fault, than I
> think this is
> a big issue and we should try to find solution or allow translators to use
> other workflows that preserve old strings.
> Alexander Bruy
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
