[Qgis-community-team] Transifex and old translations
Alexander Bruy alexander.bruy at gmail.com
Fri Nov 22 04:34:11 PST 2013
Agreed. That's why I used GIT and manual .po files update
until final decision in favor of Transifes was taken.
2013/11/22 Werner Macho <werner.macho at gmail.com>:
> Uhmmm ..
> Bad .. thats very bad ..
> But IIRC that was one of the reasons I initially skipped using
> transifex for the GUI (because the GUI is just too important)
> Hope we will find a solution so that we can switch GUI translation too ..
> kind regards
> Werner
> On Fri, Nov 22, 2013 at 12:12 PM, Alexander Bruy
> <alexander.bruy at gmail.com> wrote:
>> Hi all,
>> I just found very annoying issue that (I suspect) caused by Transifex.
>> After downloading .po files from Transifex (no matter via web interface or
>> using tx client) all old translations are empty.
>> So if I translated some text and then later original text and .po file will
>> updated, my previous translation doesn't keep. E.g. initially we have text
>> "When starting QGIS for the first time not all core plugins are loaded."
>> and I translated it and pushed this translation to Transifex. After this text
>> updated to
>> "When starting |qg| for the first time not all core plugins are loaded."
>> and all translations also updated. When I download updated file I can
>> see previous version of this string but with empty translation. And as result
>> I should translate this string again from scratch.
>> Is it me or this issue really exists? If this is not my fault, than I
>> think this is
>> a big issue and we should try to find solution or allow translators to use
>> other workflows that preserve old strings.
>> Alexander Bruy
>> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Alexander Bruy
More information about the Qgis-community-team mailing list
