[Qgis-community-team] Homogenizing filenames in documentation repo
Alexander Bruy alexander.bruy at gmail.com
Mon Oct 21 07:43:41 PDT 2013
Hi Richard,
I renamed not only sources (.rst) and translations (.po) files
in this commit, but also edited .tx/config file.
2013/10/21 Richard Duivenvoorde <richard at duif.net>:
> On 20-10-13 11:39, Alexander Bruy wrote:
>> Hi all,
>> almost all our docs doesn't have chapter numbers in their filenames.
>> I just submitted pull-request [0] where renamed all remaining files to
>> be consistent with other documentation.
>> Can anyone review and merge it, or if it looks good, I can merge it by
>> myself
>> [0] https://github.com/qgis/QGIS-Documentation/pull/164
> Hi Alexander,
> I just merged your request.
> ONE thing we have to be carefull with though, is dat the
> transifex-'resources' as they call the files via the file .tx/config are
> attached to current translations in transifex.
> I see several languages already translated parts of the 'gentle intro'...
> So after running the script
> script/create_transifex_resources.sh
> we will end up with a copy(! with number) in transifex of every file
> without a number in it's filename.
> As I understand correct now, transifex will not remove the old 'resource'.
> So BEFORE removing those old resources from transifex, the
> translator-coordinators should do this 'download translations from
> number-xxxx-file'-'upload translations from xxxxx-file'.
> OR at least I should do that before removing the old resources :-)
> I put it on my todo list.
> Regards,
> Richard
Alexander Bruy
More information about the Qgis-community-team mailing list
