[Qgis-community-team] Guidance on Training Manual Tasks
Eduardo Gonzalez eg at gismood.com
Mon Jan 13 06:21:10 PST 2014
Hello Jeff,
I see that you are also working on modules dealing with databases. It seems
that module 9 can wait for a few days in the hope that the exercise_data
for that module can be found from somewhere. Have you started working on
module 7? If you want more time for databases issues (I have very
experience with those), I can get on working with module 7 and continue
with 9 afterwards, both modules' topics are very familiar to me so it
should not be a difficult task.
Regards,
Eduardo
On Sat, Jan 11, 2014 at 2:50 AM, Jeffrey Johnson
<jjohnson at boundlessgeo.com>wrote:
> Ok, Modules 8 (Raster) and 10 (Plugins) are updated and George has
> already pulled them. See the other thread about Modules 14, 15 and the
> new one about DB Manager etc that is now 16.
> I went ahead and setup a milestone in github for this porting effort.
> https://github.com/qgis/QGIS-Documentation/issues?milestone=1&state=open
> The main outstanding modules are 7 (Vector Analysis) and 9 (Completing
> the Analysis). I will go ahead and keep working on these next week and
> hoping to have help from Victor Olaya. I believe George should be done
> with 11 (Online Resources) shortly, and Im not sure about the status
> of Module 6 (Creating Vector Data).
> Beyond that, we need to update the Appendix and Answer sheet. George,
> lets try to chat about that next week.
> I'm also keen to have a discussion about issue #190 concerning the
> sample data. It makes sense to make it as easy as possible to switch
> to a different set of exercise data for a local area with minimal
> updates to the docs themselves (i.e. remove direct references to
> Swellendam etc). This may require a bit of discussion on how best to
> do that. Might be good to have a script that can grab the necessary
> data from OSM and potentially SRTM based on a bbox and create a
> localized exercise_data directory. This will take a bit of thinking
> and editing, but I think its doable and a good idea.
> Talk to yall next week, have a good weekend.
> Jeff
> On Mon, Jan 6, 2014 at 9:05 AM, Jeffrey Johnson
> <jjohnson at boundlessgeo.com> wrote:
> > Fwiw, I was granted push access. Didnt have nearly as much time as I
> > was expecting to work on this before the holidays, but back at it this
> > week.
> > Jeff
> > On Wed, Dec 18, 2013 at 8:27 AM, Jeffrey Johnson
> >> Great. I dont have push to that repo, so cant change tags. Will ping
> >> duiv in IRC and see if he can fix that. Going to work on 10, 14 and 15
> >> in order and then come back to 7-9 as time permits and when Victor
> >> Olaya can help.
> >> Will follow up with ticket comments as well.
> >> Jeff
> >> On Tue, Dec 17, 2013 at 7:56 PM, George Irwin <george at linfiniti.com>
> wrote:
> >>> Good morning Jeff,
> >>> That all sounds great, thanks!! I’d be grateful if you could mark the
> relevant issue on github as In Progress when you start working, just so
> that everyone knows where we stand. We can also use the comments for
> targeted discussions/sharing of tasks if need be.
> >>> Thanks again
> >>> George
> >>> On 17 Dec 2013, at 23:30 , Jeffrey Johnson <jjohnson at boundlessgeo.com>
> wrote:
> >>>> I can go ahead and take on Module 10 for now to get started. Might
> >>>> make sense to just go ahead and add screenshots and let George come
> >>>> behind and replace them for consistency. I think I can also take on
> >>>> Modules 7-9 regarding processing, but will have a chat with Victor
> >>>> about that before getting started. Im also ok to take responsibility
> >>>> for 11, 14 and 15 if that works for you all.
> >>>> Will go ahead on 10 and wait to hear back from all of you.
> >>>> Jeff
> >>>> On Mon, Dec 16, 2013 at 9:33 PM, George Irwin <george at linfiniti.com>
> wrote:
> >>>>> Morning Jeff,
> >>>>> I saw Tim’s email to you last night - I’m almost half way through
> the first pass of the manual.
> >>>>> Basically what I’m doing is translating the instructions which exist
> to 2.0, incorporating a new dataset from OSM (with the option for end-users
> to replace the course data with their own localised data via the built-in
> QGIS tools) and updating and renaming the screen grabs. Ideally, all the
> screenshots should be on the same platform (for visual consistency) and it
> would make sense for the data shown in the screen grabs to be the new
> sample data with the same symbology throughout. And wherever possible, we
> can use the icons defined in the repo’s conf file.
> >>>>> The result is that I think it would be best if I continue to update
> the screenshots, simply to maintain consistency. However, it would be great
> if you could pick a module and update the text for 2.0 - anything after
> module 6. It might also be an idea to go through the new “preparing data”
> section in the introduction to make sure what I’ve described makes sense!
> At this stage, we’re not prioritising adding instructions for new features,
> but if you come across any glaring 2.0 omissions which could be
> incorporated into the workflow, please do add them.
> >>>>> Please note that I’ve still got some tidying up to do of the first 6
> chapters - through my own error, the new OSM data set was introduced after
> I’d been through those chapters, so I’m currently re-updating screenshots
> and references to the old data sets.
> >>>>> I’ll be around on IRC if I can be of any help, but thank you very
> much for helping out!
> >>>>> Yours,
> >>>>> George
> >>>>> On 16 Dec 2013, at 21:43 , Jeffrey Johnson <
> >>>>>> Hi Guys,
> >>>>>> I have time this week to contribute to the training manual. Im
> >>>>>> currently reviewing the tickets and the repo (duiv says its all in
> the
> >>>>>> manual_en_v2.0 branch). I will make sure I can build and do some
> basic
> >>>>>> review, but will be looking for guidance on the priorities after
> that.
> >>>>>> Im on IRC as jj0hns0n.
> >>>>>> Jeff
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20140113/cdc30861/attachment.html>
More information about the Qgis-community-team mailing list
