[Qgis-community-team] [Qgis-tr] latex/pdf guru's for failing Korean and Hindi pdf build available?
Ko Nagase nagase at georepublic.co.jp
Sat Jul 19 01:10:08 PDT 2014
Hi Richard,
Sorry for my late update.
I just sent pull request to Github upstream repository,
so could you check it and if there is no problem, merge it to master?
[Xelatex support for Korean and Hindi #239]
https://github.com/qgis/QGIS-Documentation/pull/239
And sorry, I still don't know well about current documentation server.
(Is it already Docker + Debian/Wheezy?)
If it is Debian/Squeeze, then please let me know.
I will try to check additional required packages and find
how to upgrade xeCJK version manually. (But it may take some time...)
If it is already Debian/Wheezy, then please install the following
additional packages.
https://github.com/sanak/QGIS-Documentation/blob/vagrant/vagrant/wheezy64/bootstrap.sh#L23-L27
Regards,
Ko
2014-06-21 16:55 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
> Hi BJ Jang,
> Okay!
> Thanks for your confirmation.
> Regards,
> Ko
> 2014-06-21 16:09 GMT+09:00 BJ Jang <qgis.tr.kr at gmail.com>:
>> Dear Ko
>> Thank you so much!!!
>> We got a perfect Korean pdf translation.
>> All about formatting(Font, spacing, images) is good!
>> Thank you again Ko.
>> Regards
>> BJ Jang
>> 2014-06-20 21:23 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>>> Hi BJ Jang, Hindi translator, Richard
>>> > BJ Jang
>>> I fixed Korean space issue by using Debian Wheezy newer xeCJK module,
>>> and applying the following link way.
>>> 2014-06-17 21:32 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>>> > [1]
>>> > http://tex.stackexchange.com/questions/17292/how-to-write-spaces-between-korean-words-with-xecjk/
>>> So, could you check the following new PDF again?
>>> Korean PDF:
>>> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-ko-wheezy.pdf
>>> > Hindi translator
>>> I added Hindi version PDF here.
>>> Hindi PDF:
>>> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-hi-wheezy.pdf
>>> I hope that someone check this one.
>>> > Richard
>>> I updated my "xelatex" branch to fix Korean space issue and add Hindi
>>> extra settings.
>>> If above files are valid ones, I will create pull request.
>>> == [xelatex] ==
>>> branch root: https://github.com/sanak/QGIS-Documentation/tree/xelatex
>>> I also created "vagrant" branch to use Debian Wheezy 7.5 x64 image on
>>> my MacOSX note PC.
>>> About package lists for the image, please see the following
>>> "bootstrap.sh".
>>> == [vagrant] ==
>>> branch root: https://github.com/sanak/QGIS-Documentation/tree/vagrant
>>> bootstrap.sh:
>>> I wrote that I will try also Debian Squeeze environement in this weekend,
>>> but I become busy with other tasks, so I set this status to pending for a
>>> while.
>>> Regards,
>>> Ko
>>> 2014-06-18 21:16 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>>> > Hi Richard, BJ Jang
>>> > Thanks for confirmation.
>>> > I just pushed yesterday code to my git repository "xelatex" branch.
>>> > commit diff:
>>> > https://github.com/sanak/QGIS-Documentation/commit/e9a02494547c5b8f7ed4581c57ee492cd9b4ecff
>>> > I confirmed Ubuntu 12.04 (precise = Debian Squeeze) xeCJK package is
>>> > too old (Version 2.3.10 (30-Sept-2009)),
>>> > and that seems to be the cause of Korean space issue.
>>> > It may also be possible to build xeCJK source by hand,
>>> > but I am not so familiar with LaTeX .etc...
>>> > Is there some plan about upgrading current documentation server to
>>> > Debian Wheezy?
>>> > Anyway, I will try to create Debian Squeeze/Wheezy environment from
>>> > scratch by Vagrant,
>>> > and check it again in this weekend, because now I am testing only on
>>> > Ubuntu 12.04 (precise).
>>> > Thanks,
>>> > 2014-06-18 20:21 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
>>> >> On 17-06-14 14:50, Ko Nagase wrote:
>>> >>> So, please check that your current "source/i18n/ko/conf.py" includes
>>> >>> both original "source/conf.py"
>>> >>> and extra "source/i18n/ko/conf.py.diff" contents.
>>> >> Thanks for the hints.
>>> >> I added this piece of config in the normal source.conf file, but do not
>>> >> get better results then the other pdf without.
>>> >> It is not clear to me if this is because of my own setup (missing
>>> >> essential korean fonts or packages) or if I'm doing something else
>>> >> wrong.
>>> >> BJ Jang: are you able to build the Korean pdf yourself?
>>> >> Any help is appreciated
>>> >> Regards,
>>> > Ko Nagase (長瀬 興)
>>> > Georepublic Japan
>>> > mail: nagase at georepublic.co.jp
>>> > web: http://georepublic.co.jp
>>> Ko Nagase (長瀬 興)
>>> Georepublic Japan
>> Open Source GIS Technical Manager / e-Cartographer
>> BJ Jang
>> Gaia3D Inc,
> Ko Nagase (長瀬 興)
> Georepublic Japan
Ko Nagase (長瀬 興)
Georepublic Japan
More information about the Qgis-community-team mailing list
