[Qgis-community-team] [Qgis-tr] latex/pdf guru's for failing Korean and Hindi pdf build available?
Ko Nagase nagase at georepublic.co.jp
Sat Jul 19 01:58:44 PDT 2014
Hi BJ Jang,
Thanks for your response.
2014-07-19 17:18 GMT+09:00 BJ Jang <qgis.tr.kr at gmail.com>:
> Thanks for your hard work.
> Your work is so helpful to me and many Korean.
No problem. :-)
> When I went to FOSS4G Osaka last year, I saw you or not, I do not know.
Oh, okay.
> If I go to Japan again, I will meet you and I would like to show
> appreciation.
Okay.
Probably I will go to Korea at next year FOSS4G 2015,
so it will be also nice timing to meet you.
> See you~
See you!
Regards,
Ko
> 2014-07-19 17:10 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>> Hi Richard,
>> Sorry for my late update.
>> I just sent pull request to Github upstream repository,
>> so could you check it and if there is no problem, merge it to master?
>> [Xelatex support for Korean and Hindi #239]
>> https://github.com/qgis/QGIS-Documentation/pull/239
>> And sorry, I still don't know well about current documentation server.
>> (Is it already Docker + Debian/Wheezy?)
>> If it is Debian/Squeeze, then please let me know.
>> I will try to check additional required packages and find
>> how to upgrade xeCJK version manually. (But it may take some time...)
>> If it is already Debian/Wheezy, then please install the following
>> additional packages.
>> https://github.com/sanak/QGIS-Documentation/blob/vagrant/vagrant/wheezy64/bootstrap.sh#L23-L27
>> Regards,
>> Ko
>> 2014-06-21 16:55 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>> > Hi BJ Jang,
>> > Okay!
>> > Thanks for your confirmation.
>> > Regards,
>> > Ko
>> > 2014-06-21 16:09 GMT+09:00 BJ Jang <qgis.tr.kr at gmail.com>:
>> >> Dear Ko
>> >> Thank you so much!!!
>> >> We got a perfect Korean pdf translation.
>> >> All about formatting(Font, spacing, images) is good!
>> >> Thank you again Ko.
>> >> Regards
>> >> BJ Jang
>> >> 2014-06-20 21:23 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>> >>> Hi BJ Jang, Hindi translator, Richard
>> >>> > BJ Jang
>> >>> I fixed Korean space issue by using Debian Wheezy newer xeCJK module,
>> >>> and applying the following link way.
>> >>> 2014-06-17 21:32 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>> >>> > [1]
>> >>> > http://tex.stackexchange.com/questions/17292/how-to-write-spaces-between-korean-words-with-xecjk/
>> >>> So, could you check the following new PDF again?
>> >>> Korean PDF:
>> >>> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-ko-wheezy.pdf
>> >>> > Hindi translator
>> >>> I added Hindi version PDF here.
>> >>> Hindi PDF:
>> >>> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-hi-wheezy.pdf
>> >>> I hope that someone check this one.
>> >>> > Richard
>> >>> I updated my "xelatex" branch to fix Korean space issue and add Hindi
>> >>> extra settings.
>> >>> If above files are valid ones, I will create pull request.
>> >>> == [xelatex] ==
>> >>> branch root: https://github.com/sanak/QGIS-Documentation/tree/xelatex
>> >>> I also created "vagrant" branch to use Debian Wheezy 7.5 x64 image on
>> >>> my MacOSX note PC.
>> >>> About package lists for the image, please see the following
>> >>> "bootstrap.sh".
>> >>> == [vagrant] ==
>> >>> branch root: https://github.com/sanak/QGIS-Documentation/tree/vagrant
>> >>> bootstrap.sh:
>> >>> I wrote that I will try also Debian Squeeze environement in this
>> >>> weekend,
>> >>> but I become busy with other tasks, so I set this status to pending
>> >>> for a
>> >>> while.
>> >>> Regards,
>> >>> Ko
>> >>> 2014-06-18 21:16 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>> >>> > Hi Richard, BJ Jang
>> >>> > Thanks for confirmation.
>> >>> > I just pushed yesterday code to my git repository "xelatex" branch.
>> >>> > branch root:
>> >>> > commit diff:
>> >>> > https://github.com/sanak/QGIS-Documentation/commit/e9a02494547c5b8f7ed4581c57ee492cd9b4ecff
>> >>> > I confirmed Ubuntu 12.04 (precise = Debian Squeeze) xeCJK package is
>> >>> > too old (Version 2.3.10 (30-Sept-2009)),
>> >>> > and that seems to be the cause of Korean space issue.
>> >>> > It may also be possible to build xeCJK source by hand,
>> >>> > but I am not so familiar with LaTeX .etc...
>> >>> > Is there some plan about upgrading current documentation server to
>> >>> > Debian Wheezy?
>> >>> > Anyway, I will try to create Debian Squeeze/Wheezy environment from
>> >>> > scratch by Vagrant,
>> >>> > and check it again in this weekend, because now I am testing only on
>> >>> > Ubuntu 12.04 (precise).
>> >>> > Thanks,
>> >>> > 2014-06-18 20:21 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
>> >>> >> On 17-06-14 14:50, Ko Nagase wrote:
>> >>> >>> So, please check that your current "source/i18n/ko/conf.py"
>> >>> >>> includes
>> >>> >>> both original "source/conf.py"
>> >>> >>> and extra "source/i18n/ko/conf.py.diff" contents.
>> >>> >> Thanks for the hints.
>> >>> >> I added this piece of config in the normal source.conf file, but do
>> >>> >> not
>> >>> >> get better results then the other pdf without.
>> >>> >> It is not clear to me if this is because of my own setup (missing
>> >>> >> essential korean fonts or packages) or if I'm doing something else
>> >>> >> wrong.
>> >>> >> BJ Jang: are you able to build the Korean pdf yourself?
>> >>> >> Any help is appreciated
>> >>> >> Regards,
>> >>> > Ko Nagase (長瀬 興)
>> >>> > Georepublic Japan
>> >>> > mail: nagase at georepublic.co.jp
>> >>> > web: http://georepublic.co.jp
>> >>> Ko Nagase (長瀬 興)
>> >>> Georepublic Japan
>> >> Open Source GIS Technical Manager / e-Cartographer
>> >> BJ Jang
>> >> Gaia3D Inc,
>> > Ko Nagase (長瀬 興)
>> > Georepublic Japan
>> Ko Nagase (長瀬 興)
>> Georepublic Japan
> BJ Jang
> Gaia3D Inc,
Ko Nagase (長瀬 興)
Georepublic Japan
More information about the Qgis-community-team mailing list
