[Qgis-community-team] website/docs build apart on qgis2, scp or rsync?
Eduardo Gonzalez eg at gismood.com
Tue Jun 10 03:59:38 PDT 2014
Hi Richard,
I tested yesterday the paver for the GIS Documentation in Windows. It
almost worked but ended with:
"Build failed running pavement.html: Subprocess return code: 1"
I run the bootstrap without problems, then activated the virtualenv, and
finally run "paver.exe html".
The process copied the files but stoped immediately when running
"sphinx-intl.exe build -l en -c source/conf.py"... the file and path for
conf.py are correct...
Any pointers?
It would be great to be able to build the autonomally and this seems to be
a great way to do it!
Regards,
Eduardo
On Sun, Apr 6, 2014 at 2:42 PM, Richard Duivenvoorde <richard at duif.net>
wrote:
> Hi,
> currently we have more or less the possibility to build docs/website
> using docker and/or paver.
> We also want to do the building on qgis2 (new server), and then move the
> static content for serving to qgis (osgeo machine).
> We 'merge' the sources of Documentation into the Website sources, during
> build. My argument was that 'searching' on qgis.org then gave you better
> results. But it also makes the build process longer and more complex
> (and double: because we also run the build for docs.qgis.org/VERSION).
> 1st Question: anybody objecting to removing this merging? It would make
> the build easier (and the pavement file easier, and reusable over
> different projects).
> 2nd Question: what is the preferred way to 'copy' the static build stuff
> to the serving server: rsync or a scp job?
> Plz think with me on how to proceed,
> Regards,
> Want to try building with Paver?
> https://github.com/qgis/QGIS-Website#building-the-website-using-paver
> Want to try Docker?
> https://github.com/qgis/QGIS-Sysadmin/blob/master/docker/sphinx/README.md
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20140610/f3d1a4c9/attachment.html>
More information about the Qgis-community-team mailing list
