[Qgis-community-team] Docker for documentation
Werner Macho werner.macho at gmail.com
Wed Nov 19 04:03:09 PST 2014
Hi Yves!
The script should build the docker image. (that way you are always up to date)
And IIRC it should use nearly the same bandwith as the prepared image
has .. so nearly no advantage on this side.
Unless you really don't want to build it by yourself (I can copy the
image to my Dropbox account for download).
Beside that: I did not know we have a qgis docker hub :)
kind regards
Werner
On Wed, Nov 19, 2014 at 11:40 AM, Yves Jacolin <yjacolin at free.fr> wrote:
> Hello,
> In documentation repository there is some script to use docker to build the
> documentation. I would like to use it. The script uses qgis/sphinx but the
> qgis docker hub is empty.
> Does someone could push this image in the QGIS docker hub?
> I would like to test the build of the documentation because someone told me
> that there are a problem with the translation update.
> Thanks,
> Y.
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
