[Qgis-community-team] Docker for documentation
Yves Jacolin yjacolin at free.fr
Wed Nov 19 04:27:03 PST 2014
Thanks Werner,
Anyway, which scripts are we talking about? :)
I have :
* docker-run.sh which need qgis/sphinx
* docker-world.sh which is not useful for me
May I miss something?
Y.
On Wednesday, November 19, 2014 13:03:09 Werner Macho wrote:
> Hi Yves!
> The script should build the docker image. (that way you are always up to
> date) And IIRC it should use nearly the same bandwith as the prepared image
> has .. so nearly no advantage on this side.
> Unless you really don't want to build it by yourself (I can copy the
> image to my Dropbox account for download).
> Beside that: I did not know we have a qgis docker hub :)
> kind regards
> Werner
> On Wed, Nov 19, 2014 at 11:40 AM, Yves Jacolin <yjacolin at free.fr> wrote:
> > Hello,
> > In documentation repository there is some script to use docker to build
> > the
> > documentation. I would like to use it. The script uses qgis/sphinx but the
> > qgis docker hub is empty.
> > Does someone could push this image in the QGIS docker hub?
> > I would like to test the build of the documentation because someone told
> > me
> > that there are a problem with the translation update.
> > Thanks,
> > Y.
More information about the Qgis-community-team mailing list
