[Qgis-community-team] Docker for documentation
Werner Macho werner.macho at gmail.com
Wed Nov 19 04:31:24 PST 2014
looks like I am missing something ..
Last time I saw the scripts there was no need for qgis/sphinx because
it got built ..
Give me some time to take a look
regards
Werner
On Wed, Nov 19, 2014 at 1:27 PM, Yves Jacolin <yjacolin at free.fr> wrote:
> Thanks Werner,
> Anyway, which scripts are we talking about? :)
> I have :
> * docker-run.sh which need qgis/sphinx
> * docker-world.sh which is not useful for me
> May I miss something?
> Y.
> On Wednesday, November 19, 2014 13:03:09 Werner Macho wrote:
>> Hi Yves!
>> The script should build the docker image. (that way you are always up to
>> date) And IIRC it should use nearly the same bandwith as the prepared image
>> has .. so nearly no advantage on this side.
>> Unless you really don't want to build it by yourself (I can copy the
>> image to my Dropbox account for download).
>> Beside that: I did not know we have a qgis docker hub :)
>> kind regards
>> Werner
>> On Wed, Nov 19, 2014 at 11:40 AM, Yves Jacolin <yjacolin at free.fr> wrote:
>> > Hello,
>> > In documentation repository there is some script to use docker to build
>> > the
>> > documentation. I would like to use it. The script uses qgis/sphinx but the
>> > qgis docker hub is empty.
>> > Does someone could push this image in the QGIS docker hub?
>> > I would like to test the build of the documentation because someone told
>> > me
>> > that there are a problem with the translation update.
>> > Thanks,
>> > Y.
More information about the Qgis-community-team mailing list
