[Qgis-community-team] Processing help
Paolo Cavallini cavallini at faunalia.it
Mon Nov 24 00:15:47 PST 2014
Il 22/11/2014 18:37, Alexander Bruy ha scritto:
> Done, results available in my repo, branch processing-help [0].
> Almost all help files are just templates, but TauDEM is fully
> documented.
> Also I add some guidelines to documentation guidelines document.
> Comments and suggestions about are welcome. When we will be
> happy with results I merge this into main documenation repo.
> [0] https://github.com/alexbruy/QGIS-Documentation/tree/processing-help
Hi Alex,
I assume the help you moved into documentation is also used inside Processing (tab
Help), right? Is this duplicated? Ho do you plan to use the same text in both?
Thanks a lot.
All the best.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
More information about the Qgis-community-team mailing list
