[Qgis-community-team] Processing help
Alexander Bruy alexander.bruy at gmail.com
Mon Nov 24 07:04:39 PST 2014
Hi Paolo,
yes this help wa initialy created to be used in Processing Help tab.
But right now it not included in Processing distribution, so there is
no duplication.
2014-11-24 10:15 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 22/11/2014 18:37, Alexander Bruy ha scritto:
>> Done, results available in my repo, branch processing-help [0].
>> Almost all help files are just templates, but TauDEM is fully
>> documented.
>> Also I add some guidelines to documentation guidelines document.
>> Comments and suggestions about are welcome. When we will be
>> happy with results I merge this into main documenation repo.
>> [0] https://github.com/alexbruy/QGIS-Documentation/tree/processing-help
> Hi Alex,
> I assume the help you moved into documentation is also used inside Processing (tab
> Help), right? Is this duplicated? Ho do you plan to use the same text in both?
> Thanks a lot.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
Alexander Bruy
More information about the Qgis-community-team mailing list
