[Qgis-community-team] Please finalise work on documentation
Alexander Bruy alexander.bruy at gmail.com
Sat Nov 29 08:20:36 PST 2014
Solution with conf.py look good for me. It is very easy to uncomment
desired lines and run build. If others also have no objections I think we
can proceed with this
2014-11-29 18:11 GMT+02:00 Richard Duivenvoorde <richard at duif.net>:
> On 29-11-14 13:58, Alexander Bruy wrote:
> > not sure if this really necessary, but what about some
> > tweaks in Makefile that allow us exclude Processing
> > help from build when needed
> Yep, I tried here, that is easy:
> For example to only build the 'documentation_guidelines' part of the
> docs, adding something like:
> exclude_patterns += ['docs/training_manual/*', 'docs/user_manual/*',
> 'docs/gentle_gis_introduction/*', 'docs/pyqgis_developer_cookbook/*']
> after exclude_patterns value in source/conf.py,
> makes sphinx just ignore the other docs
> So a
> exclude_patterns += ['docs/user_manual/processing_algs/*',
> 'docs/training_manual/*', 'docs/documentation_guidelines/*',
> will build you ONLY a user_manual, but WITHOUT processing_algs
> What do you think is best, we could create some Makefile targets, or
> maybe a Makefile variable which you can bring in.
> But actually describe/document that it is that easy to edit the
> source/conf.py will make it easy for documentation builders to do this
> partial builds.
> And by doing it in the conf.py, we do not have to duplicate that switch
> in both Makefile and Paver configs....
> So what about adding the following to the conf.py, all commented, so
> user which wants to build can easily exclude stuff:
> # uncomment to exclude the processing algs from build
> #exclude_patterns += ['docs/user_manual/processing_algs/*']
> # uncomment to exclude the user manual from build
> #exclude_patterns += ['docs/user_manual/*']
> # uncomment to exclude training manual from build
> #exclude_patterns += ['docs/training_manual/*']
> # uncomment to exclude doc guides from build
> #exclude_patterns += ['docs/documentation_guidelines/*']
> # uncomment to exclude gentle intro  from build
> #exclude_patterns += ['docs/gentle_gis_introduction/*']
> # uncomment to exclude pyqgis dev book from build
> #exclude_patterns += ['docs/pyqgis_developer_cookbook/*']
> Ok, would that be clear/easy enough for the average builder?
> Or would we prefer to add switches?
> Regards,
Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20141129/b1efaf56/attachment-0001.html>
More information about the Qgis-community-team mailing list
