[Qgis-community-team] Looking for data to use in qgs-projects for screenshots
DelazJ delazj at gmail.com
Tue Nov 24 08:38:53 PST 2015
Thanks
Yes, Richard, I've seen this path but since it's a relative one I couldn't
figure out what was the parent folder, ignoring that sample data needed to
be downloaded from another repo.
So Alexandre, please, make it more explicite since we don't all
remember/know where and what's the QGIS Data sample repo.
Thanks to both of u.
2015-11-24 17:27 GMT+01:00 Richard Duivenvoorde <richard at duif.net>:
> On 24-11-15 16:50, DelazJ wrote:
> > According to
> http://docs.qgis.org/testing/en/docs/documentation_guidelines/README.html#add-new-screenshots
> > there are qgis projects that can be used to shape screenshots for the
> > QGIS-Documentation project.
> > I can find the project files at
> https://github.com/qgis/QGIS-Documentation/tree/master/qgis-projects/user_manual
> > but QGIS is unable to reach the data sources. The link to data in the
> > qgs file seems broken and no shp file is present in the repository.
> > Am I missing something? Any idea where I can find the data?
> For what I know the data used for all screenshots come from the Alaska
> data set:
> http://qgis.org/downloads/data/qgis_sample_data.zip
> If you look into the xml of the qgis files, you see relative paths to
> shapefiles:
> <datasource>../../../qgis_sample_data/shapefiles/rivers.shp</datasource>
> see:
> https://github.com/qgis/QGIS-Documentation/blob/master/qgis-projects/user_manual/working_with_vector_02.qgs#L4147
> So:
> if you download the zip, unpack it and put the folder in the same
> directory as you have QGIS-Documentation folder, the qgis files 'just
> work' :-)
> Note: I checked on qgs file and see there is also a postgis connection
> in it... but the shapefiles loaded.
> Hope this helps.
> Regards,
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20151124/e20c67f3/attachment-0001.html>
More information about the Qgis-community-team mailing list
