[Qgis-community-team] hmtl index name of Processing algorithms
DelazJ
delazj at gmail.com
Wed Jun 28 06:55:45 PDT 2017
Hi Matteo,
Links to algorithms are generated using the path to the file + chapter +
the section title (which should be the alg name), hence ALL algs are
normally provided with a link ended with their name...
As you may notice, the first link you provide (the id one) is the link to
the algorithm in the page Table of content. It doesn't lead to the
algorithm description itself. But
http://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/vector_creation_tools.html#random-points-along-line
does (clicking the title or the widget aside makes the difference).
Id links are only internal sequential link generated in the concerned page,
hence can change if new links are created above... They shouldn't be used
as persistent link imho...
Harrissou
2017-06-28 15:36 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
> Hi all,
> I'm seeing that the permalink of the processing algorithms on the
> website does not end with the algorithm name, but with an id:
> processing_algs/qgis/vector_creation_tools.html#id46
> is there a reason for id? IMHO it would be better to have the name of
> the algorithm itself in the permalink, like:
> processing_algs/qgis/vector_creation_tools.html#create_grid
> Any opinions?
> Cheers
> Matteo
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20170628/ea883497/attachment.html>
More information about the Qgis-community-team
