[Qgis-community-team] hmtl index name of Processing algorithms
DelazJ delazj at gmail.com
Wed Jun 28 07:10:51 PDT 2017
nota: create_grids alg is actually the current id46 and not
random-points-along-line (as I sent earlier)
And yes, doc help ( for algorithm and common dialogs) should rely on the
full and readable/understandable link instead of the id's. I'd even favor
using rst internal anchors (which could ensure that help sections are
always retrieved even if the chapters are restructured but no idea what it
requires nor if possible(/desirable)).
2017-06-28 15:55 GMT+02:00 DelazJ <delazj at gmail.com>:
> Hi Matteo,
> Links to algorithms are generated using the path to the file + chapter +
> the section title (which should be the alg name), hence ALL algs are
> normally provided with a link ended with their name...
> As you may notice, the first link you provide (the id one) is the link to
> the algorithm in the page Table of content. It doesn't lead to the
> algorithm description itself. But http://docs.qgis.org/testing/
> en/docs/user_manual/processing_algs/qgis/vector_
> creation_tools.html#random-points-along-line does (clicking the title or
> the widget aside makes the difference).
> Id links are only internal sequential link generated in the concerned
> page, hence can change if new links are created above... They shouldn't be
> used as persistent link imho...
> Harrissou
> 2017-06-28 15:36 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
>> Hi all,
>> I'm seeing that the permalink of the processing algorithms on the
>> website does not end with the algorithm name, but with an id:
>> http://docs.qgis.org/testing/en/docs/user_manual/processing_
>> algs/qgis/vector_creation_tools.html#id46
>> is there a reason for id? IMHO it would be better to have the name of
>> the algorithm itself in the permalink, like:
>> algs/qgis/vector_creation_tools.html#create_grid
>> Any opinions?
>> Cheers
>> Matteo
>> Qgis-community-team mailing list for organizing community resources such
>> as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20170628/7d86b629/attachment.html>
More information about the Qgis-community-team mailing list
