[Qgis-community-team] hmtl index name of Processing algorithms
matteo matteo.ghetta at gmail.com
Wed Jun 28 07:44:22 PDT 2017
Hi Harrissou,
On 06/28/2017 03:55 PM, DelazJ wrote:
> Hi Matteo,
> Links to algorithms are generated using the path to the file + chapter +
> the section title (which should be the alg name), hence ALL algs are
> normally provided with a link ended with their name...
> As you may notice, the first link you provide (the id one) is the link to
> the algorithm in the page Table of content. It doesn't lead to the
> algorithm description itself. But
> http://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/vector_creation_tools.html#random-points-along-line
> does (clicking the title or the widget aside makes the difference).
ehehe this make perfect sense to.. it seemed strange to me this behavior
change..
> Id links are only internal sequential link generated in the concerned page,
> hence can change if new links are created above... They shouldn't be used
> as persistent link imho...
got it, perfect, thanks again Harrissou!
Cheers
Matteo
More information about the Qgis-community-team mailing list
