[Qgis-community-team] [QGIS-Developer] QGIS documentation build is failing and is making me crazy. Heeellp!!!!
DelazJ delazj at gmail.com
Wed Jun 26 04:04:54 PDT 2019
OK. Thanks Alex. Looking forward.
Meanwhile, I came accross some global variables
https://www.sphinx-doc.org/en/master/usage/extensions/doctest.html#configuration
Cheers,
Harrissou
Le mer. 26 juin 2019 à 11:59, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> Hi Harrissou,
> I think you are over thinking it. We don't need to revert everything, We
> just need to make sure that certain variables are initialized or fully
> replaced in each rst file to be tested. For example, if we have a project
> instance where layers are added in different rst files, it will be hard to
> guess the status of that project everytime.
> I will try to have a look at it later. I am not an experienced PyQGIS guy,
> but I think I can stab it.
> Thanks,
> Alex
> On Wed, Jun 26, 2019 at 8:50 AM matteo <matteo.ghetta at gmail.com> wrote:
>> Same here. Ran locally and no failures
>> Matteo
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190626/47db9d27/attachment-0001.html>
More information about the Qgis-community-team mailing list
