[Qgis-community-team] Documentation wish list for "hackfesters"
DelazJ
delazj at gmail.com
Mon Sep 16 13:02:49 PDT 2019
Hi Raymond,
Le lun. 16 sept. 2019 à 18:47, Raymond Nijssen <r.nijssen at terglobo.nl> a
écrit :
> Hi Harrissou!
> How are you? Thanks for the reminder.
> I'm fine, thanks. Hope you are fine, too.
During the hf I've been working quite some time on the cookbook, to be
> exactly on the vector-layer page I started with in A Coruna. I'm halfway
> now, at the part where "Symbology" starts. Should I put it in a branch
> and share it already? I kind of hope that the symbology part will be
> easier and faster.
> Thanks for taking care of this. If you think it's in a mergeable state and
can be reviewed, I think it could be nice to publish and have pythonista
review it. It would result in less outdated information in the Cookbook.
If I'm not wrong, a part of the symbology section has been recently updated
so less to do.
Greetings,
Harrissou
Kind regards,
> Raymond
> On 16-09-19 17:57, DelazJ wrote:
> > Hi all,
> > The hackfest has gone for weeks, but QGIS is still there as well as
> > writers and developers. So I wonder if someone had considered the
> > opportunity to give a hand on any of the identified issues.
> > /NB: It could not be for the "Spare Time Inc" since we still have
> > unallocated funds (and not "founds" - damn keyboard)./
> > Regards,
> > Harrissou
> > Le ven. 23 août 2019 à 18:21, DelazJ <delazj at gmail.com
> > <mailto:delazj at gmail.com>> a écrit :
> > Hi all,
> > With the QGIS Community Meeting beginning, a bunch of developers and
> > writers will meet to brainstorm and improve QGIS. Here are some
> > suggestions of topics (among many others) some documentation
> > contributors would be REALLY interested in having a fix for. We need
> > a developer to address and ease our "life" (sounds tragical enough?
> > :D ). Well.
> > In short:
> > 1/ *Improve the automatic creation of screenshots* [1]
> > 2/ *Redirect docs links *and ensure that changing links in docs does
> > *not break the help button* in application [3]
> > 3/ *Document/improve the doctest architecture for PyQGIS Cookbook
> > *(kind of [4])
> > For the details:
> > 1/ QGIS is moving fast. Dialogs are changing at every release,
> > making screenshots in the docs obsolete. There was a plan to avoid
> > writers manually take each screenshot, and instead generate them in
> > series, browsing tabs of a specified dialog eg. A work had been
> > initiated in the QgsAppScreenshots class [1]. It could be nice to
> > get more news on it.
> > Incidentally, with such a feature, we can expect more translated
> > screenshots (which may not be good for our server but helpful for
> > non-English readers and translators).
> > 2/ Because features are getting bigger, we sometimes need to
> > reorganize the chapters in documentation in order to match how
> > things behave in the application and also avoid very loooong
> > chapters. Moving sections or renaming them (to match their actual
> > scope) breaks the Help button associated to the feature, for at
> > least three releases (the next-to-be LTR and the two previous
> > versions since they point to the same doc). To fix that, doc writers
> > have to update the links in the code and this change only applies to
> > current release(s), not for EOLed one (eg 3.6 could have more not
> > working links than 3.8 or master - we have a script for checks [2]).
> > We need to find a more viable way to address this issue and redirect
> > requested links to their actual place in the corresponding doc.
> > This issue is a long standing one that has been reported/discussed a
> > couple of times already (eg [3] has some suggestions)
> > 3/ During the La Coruna hackfest, a doctest infrastructure has been
> > set up to ensure code samples provided for PyQGIS Cookbook are still
> > working. Months later, it looks to me like it's less used than it
> > should:
> > - partly, because we did not make it mandatory,
> > - partly because it does not apply (or we did not figure out how?)
> > in some cases. Eg it seems it does not know about iface [4]. Also
> > there are test projects the system should rely on but nobody uses it
> > and afaics there's no example someone not used to this could follow.
> > It could be nice clarifying the system and help writers adopt it.
> > [1]
> https://github.com/qgis/QGIS/blob/master/src/app/qgsappscreenshots.h
> > [2] https://github.com/qgis/QGIS/blob/master/scripts/chkdoclink.sh
> > [3]
> https://github.com/qgis/QGIS-Documentation/pull/2258#issuecomment-352246124
> > [4] https://github.com/qgis/QGIS-Documentation/issues/3776
> > Et voilà... Sorry to have been long. Looking forward...
> > And for information, docs still have unallocated founds...
> > Happy hackfest,
> > Harrissou
> > Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> > Qgis-community-team at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190916/374e9d7e/attachment.html>
More information about the Qgis-community-team
