[Qgis-community-team] can somebody help me - update my master
Etienne Trimaille etienne.trimaille at gmail.com
Thu Feb 13 09:34:57 PST 2020
Can you explain what do you mean by "my master" ? Do you mean your master
branch ON your computer or your master branch ON github (your github
repository) ?
In the case of your master on github, I usually let it, it's far behind,
because usually it's doesn't hurt to have it behind. Nobody use it.
For your master branch on your computer, you can do:
git checkout master
git merge upstream/master (to merge from "upstream")
Then, only if you want to update your master on github, you can do
git push origin master
But I honestly never do this command. And I don't use a PR too.
PS : I'm assuming your remote are called upstream and origin, like:
etienne at longitude:~/dev/qgis/QGIS-Documentation (master)$ git remote -v
origin git at github.com:Gustry/QGIS-Documentation.git (fetch)
origin git at github.com:Gustry/QGIS-Documentation.git (push)
upstream https://github.com/qgis/QGIS-Documentation.git (fetch)
upstream https://github.com/qgis/QGIS-Documentation.git (push)
In the Netherlands next month, just ask us ;-)
What Alexandre said works too if you want to update your master on github.
Le jeu. 13 févr. 2020 à 18:12, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> I think you are in the right track.
> 1. Click on Pull Requests
> 2. Click new
> 3. Click on compare between forks
> 4. Use your fork (ljunek\master) as base and QGIS\master as Head
> 5. Click create pull request
> 6. Give it a name like update master a click create pull request.
> 7. With the pull request created, in the bottom, select merge.
> That should be it.
> Alex
> A quinta, 13/02/2020, 16:04, Larissa Junek <l.junek at gmx.net> escreveu:
>> Hello folks,
>> again I'm stuck into gitHub here. I just want to update my master with
>> the latest commits. Some weeks ago I made a useless update in the QGIS
>> Documentation master to update. Now here, I'm asked to make a pull request
>> about stuff the others were contributing.
>> Can somebody tell me the steps how I can just update my master?
>> @Alexandre sorry for this mistake, I should know how to update my master.
>> Cheers, Larissa
>> Qgis-community-team mailing list for organizing community resources such
>> as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200213/7b2da909/attachment.html>
More information about the Qgis-community-team mailing list
