[Qgis-community-team] can somebody help me - update my master
Alexandre Neto senhor.neto at gmail.com
Thu Feb 13 09:42:45 PST 2020
Hi Etienne,
Larissa uses solely github web interface to edit the documentation, that's
why she needs the master branch on her fork updated regularly.
Alexandre Neto
A quinta, 13/02/2020, 17:35, Etienne Trimaille <etienne.trimaille at gmail.com>
escreveu:
> Can you explain what do you mean by "my master" ? Do you mean your master
> branch ON your computer or your master branch ON github (your github
> repository) ?
> In the case of your master on github, I usually let it, it's far behind,
> because usually it's doesn't hurt to have it behind. Nobody use it.
> For your master branch on your computer, you can do:
> git checkout master
> git merge upstream/master (to merge from "upstream")
> Then, only if you want to update your master on github, you can do
> git push origin master
> But I honestly never do this command. And I don't use a PR too.
> PS : I'm assuming your remote are called upstream and origin, like:
> etienne at longitude:~/dev/qgis/QGIS-Documentation (master)$ git remote -v
> origin git at github.com:Gustry/QGIS-Documentation.git (fetch)
> origin git at github.com:Gustry/QGIS-Documentation.git (push)
> upstream https://github.com/qgis/QGIS-Documentation.git (fetch)
> upstream https://github.com/qgis/QGIS-Documentation.git (push)
> In the Netherlands next month, just ask us ;-)
> What Alexandre said works too if you want to update your master on github.
> Le jeu. 13 févr. 2020 à 18:12, Alexandre Neto <senhor.neto at gmail.com> a
> écrit :
>> I think you are in the right track.
>> 1. Click on Pull Requests
>> 2. Click new
>> 3. Click on compare between forks
>> 4. Use your fork (ljunek\master) as base and QGIS\master as Head
>> 5. Click create pull request
>> 6. Give it a name like update master a click create pull request.
>> 7. With the pull request created, in the bottom, select merge.
>> That should be it.
>> Alex
>> A quinta, 13/02/2020, 16:04, Larissa Junek <l.junek at gmx.net> escreveu:
>>> Hello folks,
>>> again I'm stuck into gitHub here. I just want to update my master with
>>> the latest commits. Some weeks ago I made a useless update in the QGIS
>>> Documentation master to update. Now here, I'm asked to make a pull request
>>> about stuff the others were contributing.
>>> Can somebody tell me the steps how I can just update my master?
>>> @Alexandre sorry for this mistake, I should know how to update my master.
>>> Cheers, Larissa
>>> Qgis-community-team mailing list for organizing community resources such
>>> as documentation, translation etc..
>>> Qgis-community-team at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20200213/793c9e7c/attachment.html>
More information about the Qgis-community-team mailing list
