[Qgis-community-team] Renaming Style Manager?
Andreas Neumann a.neumann at carto.net
Tue Jan 18 07:39:02 PST 2022
Maybe "Layer configuration"?
Andreas
On 2022-01-18 16:30, Jörn Gutzeit wrote:
> Hi,
> I agree with Alex: don't want to add to the confusion, but doing it
> anyway :-)
> When I read it, I thought: right, also for me the word ‚style' means
> how something looks and IMHO that is what is managed in the Style
> Manager. And a QML file stores (by now?) more than that.
> After thinking about it: for me, what is stored in a QML file is best
> described as ‚Layer Properties Settings', but that's probably too long
> ;-) Could it just be called ‚Layer Properties' or ‚Layer Settings'? I
> prefer Layer Settings, then a QML file would be a Layer Settings File.
> Jörn
> Am 15.01.22 um 11:14 schrieb Alexandre Neto:
> Not wanting to add more confusion, but adding it anyway :-p
> Maybe it's not the style manager that that needs to be changed, but the
> term "style" itself and how it is used.
> At least for me the word style is related to the way something looks.
> In QGIS, when you save a "style" you are actually saving many of the
> layer "properties" and not all are related to the way the layer will
> look.
> So style could be reserved to symbols, labels, color ramps, and so
> on... And maybe we need another term for what we call style now.
> We also have Layer Definition Files.
> My two cents.
> Alex
> A sexta, 14/01/2022, 21:06, Charles Dixon-Paver <charles at kartoza.com>
> escreveu:
> +1 for Design Manager
> On Fri, 14 Jan 2022 at 23:00, Anita Graser <anitagraser at gmx.at> wrote:
> Thanks Harrissou and Jörn,
> Good to see all these previous discussions. Seems like everyone agrees
> that "Style Manager" has to be renamed but we don't have a good
> alternative yet. As Nyall said in
> https://github.com/qgis/QGIS/pull/2765, "Symbol Manager" is not correct
> either.
> We're looking for an umbrella term that covers: symbols, color ramps,
> text formats, label settings, legend patch shapes, and 3D symbols.
> We use "resources" in the Resource Manager, however that's for
> "Symbology (SVG, images, styles), Processing scripts, Processing
> models, R scripts and checklists" (according to
> https://plugins.qgis.org/plugins/qgis_resource_sharing/).
> Brainstorming:
> * Cartography Resources
> * Visual Library
> * Design Manager
> What do you think about "design"?
> Regards,
> Anita
> On 14.01.2022 21:25, Jörn Gutzeit wrote: Hi,
> I also recently had a confusion between style/style: I wanted to write
> the documentation for the new feature "Save all styles" and first
> searched for it in the style manger (also because the issue has the tag
> "style manager" ... ;-) ). The new feature, however, makes it possible
> to save several styles from the layer properties dialog as QML/SLD
> files or in a db [1].
> Now we are in a discussion how to separate this styles in the chapter
> (all layer properties) and the style manager (symbols only) [2].
> Renaming the style manager might help ...
> Regards,
> Jörn
> [1] https://github.com/qgis/QGIS-Documentation/issues/4398
> [2] https://github.com/qgis/QGIS-Documentation/pull/7217
> Am 14.01.2022 um 16:39 schrieb Delaz J:
> Hi Anita, all
> The inconsistent use of the word "style" is indeed an issue and
> confusing. It was raised years ago in
> https://github.com/qgis/qgis3_UIX_discussion/issues/16 (and probably in
> QGIS repo but hard to find) with an attempt of fix at
> https://github.com/qgis/QGIS/pull/2765 (you'll find some answers to
> your suggestion of symbol manager).
> Maybe the time has come for the cleanup...?
> Regards,
> Harrissou
> Le 14/01/2022 à 13:14, Anita Graser a écrit :
> Hi,
> This question was triggered by Tim at
> https://github.com/qgis/QGIS-Django/issues/231
> The terms "style" and "symbol" are used somewhat inconsistently in the
> QGIS application and on the QGIS hub website. For example, in Settings
> Style Manager the users actually manage symbols. On the hub, the
> "styles" page allows sharing symbol definitions (XML) but not styles
> (QML).
> This later inconsistency is confusing, i.e. it confused me when I
> wanted
> to share a QML file and realized that I cannot.
> I think it would be worthwhile to strive for more consistency and to
> rename the Style Manager because it really is a symbol manager. It's
> Import/Export functionality deals with XML symbols and not QML styles.
> What do you think?
> Regards,
> Anita
> Qgis-community-team mailing list for organizing community resources
> such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
Qgis-community-team mailing list for organizing community resources such
Jörn Gutzeit Umwelt IT
Umweltdatenbearbeitung
Lothringerstraße 68
52070 Aachen
0176 - 43 03 93 31
www.umwelt-it.de [1]
Links:
[1] http://www.umwelt-it.de
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20220118/d7839376/attachment-0001.html>
More information about the Qgis-community-team mailing list
