[Qgis-community-team] pdf testing build failing
DelazJ delazj at gmail.com
Fri Mar 4 01:49:53 PST 2022
It seems there is also
https://github.com/qgis/QGIS-Documentation/blob/master/docs/user_manual/working_with_vector/img/self_snapping.gif
Le ven. 4 mars 2022 à 10:46, DelazJ <delazj at gmail.com> a écrit :
> Hi Richard,
> The gif in recent docs not available in 3.16 that I can think of is
> https://github.com/qgis/QGIS-Documentation/blob/master/docs/user_manual/introduction/img/map_navigation.gif
> Worth trying a build without?
> Regards,
> Harrissou
> Le ven. 4 mars 2022 à 09:10, Richard Duivenvoorde <rdmailings at duif.net> a
> écrit :
>> Hi, Any Latex/PDF guru's here?
>> The pdf build of current testing version of the docs is failing.
>> Normally we do a Latex build and after that a pdf generation.
>> 3.16 is still fine (build yesterday I see in pdf of 3.16)
>> But building testing here locally:
>> Latex build is fine, then pdf generation generates output below.
>> I'm thinking about a poissonous GIF image? Anybody aware of maybe
>> animated gifs or so?
>> See below for the build error
>> Regards,
>> This is XeTeX, Version 3.141592653-2.6-0.999993 (TeX Live
>> 2022/dev/Debian) (preloaded format=xelatex)
>>   \write18 enabled.
>> entering extended mode
>> Error: /undefined in GIF89ax��
>> Operand stack:
>> Execution stack:
>>     %interp_exit   .runexec2   --nostringval--   --nostringval--
>>  --nostringval--   2   %stopped_push   --nostringval--   --nostringval--
>>  --nostringval--   false   1   %stopped_push   1990   1   3   %oparray_pop
>>  1989   1   3   %oparray_pop   1977   1   3   %oparray_pop   1833   1   3
>>  %oparray_pop   --nostringval--   %errorexec_pop   .runexec2
>>  --nostringval--   --nostringval--   --nostringval--   2   %stopped_push
>>  --nostringval--
>> Dictionary stack:
>>     --dict:770/1123(ro)(G)--   --dict:0/20(G)--   --dict:75/200(L)--
>> Current allocation mode is local
>> Current file position is 12
>> GPL Ghostscript 9.55.0: Unrecoverable error, exit code 1
>> xdvipdfmx:fatal: pdf_link_obj(): passed invalid object.
>> No output PDF file written.
>>   \write18 enabled.
>> Operand stack:
>> Execution stack:
>>  --nostringval--
>> Dictionary stack:
>> Qgis-community-team mailing list for organizing community resources such
>> as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20220304/f48c6f54/attachment.html>
More information about the Qgis-community-team mailing list
