[Qgis-community-team] pdf testing build failing
Alexandre Neto senhor.neto at gmail.com
Fri Mar 4 07:02:22 PST 2022
Maybe we need to wrap those animated gifs in the .. only:: directives to
avoid showing in the PDF. They probably will be useless anyway in the PD.
DelazJ <delazj at gmail.com> escreveu no dia sexta, 4/03/2022 à(s) 09:50:
> It seems there is also
> https://github.com/qgis/QGIS-Documentation/blob/master/docs/user_manual/working_with_vector/img/self_snapping.gif
> Le ven. 4 mars 2022 à 10:46, DelazJ <delazj at gmail.com> a écrit :
>> Hi Richard,
>> The gif in recent docs not available in 3.16 that I can think of is
>> https://github.com/qgis/QGIS-Documentation/blob/master/docs/user_manual/introduction/img/map_navigation.gif
>> Worth trying a build without?
>> Regards,
>> Harrissou
>> Le ven. 4 mars 2022 à 09:10, Richard Duivenvoorde <rdmailings at duif.net>
>> a écrit :
>>> Hi, Any Latex/PDF guru's here?
>>> The pdf build of current testing version of the docs is failing.
>>> Normally we do a Latex build and after that a pdf generation.
>>> 3.16 is still fine (build yesterday I see in pdf of 3.16)
>>> But building testing here locally:
>>> Latex build is fine, then pdf generation generates output below.
>>> I'm thinking about a poissonous GIF image? Anybody aware of maybe
>>> animated gifs or so?
>>> See below for the build error
>>> Regards,
>>> This is XeTeX, Version 3.141592653-2.6-0.999993 (TeX Live
>>> 2022/dev/Debian) (preloaded format=xelatex)
>>>   \write18 enabled.
>>> entering extended mode
>>> Error: /undefined in GIF89ax��
>>> Operand stack:
>>> Execution stack:
>>>     %interp_exit   .runexec2   --nostringval--   --nostringval--
>>>  --nostringval--   2   %stopped_push   --nostringval--   --nostringval--
>>>  --nostringval--   false   1   %stopped_push   1990   1   3   %oparray_pop
>>>  1989   1   3   %oparray_pop   1977   1   3   %oparray_pop   1833   1   3
>>>  %oparray_pop   --nostringval--   %errorexec_pop   .runexec2
>>>  --nostringval--   --nostringval--   --nostringval--   2   %stopped_push
>>>  --nostringval--
>>> Dictionary stack:
>>>     --dict:770/1123(ro)(G)--   --dict:0/20(G)--   --dict:75/200(L)--
>>> Current allocation mode is local
>>> Current file position is 12
>>> GPL Ghostscript 9.55.0: Unrecoverable error, exit code 1
>>> xdvipdfmx:fatal: pdf_link_obj(): passed invalid object.
>>> No output PDF file written.
>>>   \write18 enabled.
>>> Operand stack:
>>> Execution stack:
>>>  --nostringval--
>>> Dictionary stack:
>>> Qgis-community-team mailing list for organizing community resources such
>>> as documentation, translation etc..
>>> Qgis-community-team at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20220304/f004c541/attachment-0001.html>
More information about the Qgis-community-team mailing list
