[Qgis-community-team] pdf testing build failing
DelazJ delazj at gmail.com
Fri Mar 4 07:04:00 PST 2022
Yes Alexandre, I forgot that one actually. Done per
https://github.com/qgis/QGIS-Documentation/pull/7381
Le ven. 4 mars 2022 à 16:02, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> Maybe we need to wrap those animated gifs in the .. only:: directives to
> avoid showing in the PDF. They probably will be useless anyway in the PD.
> DelazJ <delazj at gmail.com> escreveu no dia sexta, 4/03/2022 à(s) 09:50:
>> It seems there is also
>> https://github.com/qgis/QGIS-Documentation/blob/master/docs/user_manual/working_with_vector/img/self_snapping.gif
>> Le ven. 4 mars 2022 à 10:46, DelazJ <delazj at gmail.com> a écrit :
>>> Hi Richard,
>>> The gif in recent docs not available in 3.16 that I can think of is
>>> https://github.com/qgis/QGIS-Documentation/blob/master/docs/user_manual/introduction/img/map_navigation.gif
>>> Worth trying a build without?
>>> Regards,
>>> Harrissou
>>> Le ven. 4 mars 2022 à 09:10, Richard Duivenvoorde <rdmailings at duif.net>
>>> a écrit :
>>>> Hi, Any Latex/PDF guru's here?
>>>> The pdf build of current testing version of the docs is failing.
>>>> Normally we do a Latex build and after that a pdf generation.
>>>> 3.16 is still fine (build yesterday I see in pdf of 3.16)
>>>> But building testing here locally:
>>>> Latex build is fine, then pdf generation generates output below.
>>>> I'm thinking about a poissonous GIF image? Anybody aware of maybe
>>>> animated gifs or so?
>>>> See below for the build error
>>>> Regards,
>>>> This is XeTeX, Version 3.141592653-2.6-0.999993 (TeX Live
>>>> 2022/dev/Debian) (preloaded format=xelatex)
>>>>   \write18 enabled.
>>>> entering extended mode
>>>> Error: /undefined in GIF89ax��
>>>> Operand stack:
>>>> Execution stack:
>>>>     %interp_exit   .runexec2   --nostringval--   --nostringval--
>>>>  --nostringval--   2   %stopped_push   --nostringval--   --nostringval--
>>>>  --nostringval--   false   1   %stopped_push   1990   1   3   %oparray_pop
>>>>  1989   1   3   %oparray_pop   1977   1   3   %oparray_pop   1833   1   3
>>>>  %oparray_pop   --nostringval--   %errorexec_pop   .runexec2
>>>>  --nostringval--   --nostringval--   --nostringval--   2   %stopped_push
>>>>  --nostringval--
>>>> Dictionary stack:
>>>>     --dict:770/1123(ro)(G)--   --dict:0/20(G)--   --dict:75/200(L)--
>>>> Current allocation mode is local
>>>> Current file position is 12
>>>> GPL Ghostscript 9.55.0: Unrecoverable error, exit code 1
>>>> xdvipdfmx:fatal: pdf_link_obj(): passed invalid object.
>>>> No output PDF file written.
>>>>   \write18 enabled.
>>>> Operand stack:
>>>> Execution stack:
>>>>  --nostringval--
>>>> Dictionary stack:
>>>> _______________________________________________
>>>> Qgis-community-team mailing list for organizing community resources
>>>> such as documentation, translation etc..
>>>> Qgis-community-team at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>> Qgis-community-team mailing list for organizing community resources such
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20220304/ec853beb/attachment.html>
More information about the Qgis-community-team mailing list
