[Qgis-community-team] Archive Documentation 3.16
Alexandre Neto senhor.neto at gmail.com
Thu Mar 31 04:00:16 PDT 2022
Richard,
I agree with you, we don't need all those links in there. But as far as I
remember, the 2.x versions are the problematic ones, more recent ones
should have the canonical URL set that in searches should point to newer
versions. At least in theory! :-P
Alex
On Thu Mar 31, 2022, 10:56 AM GMT, Alexandre Neto <senhor.neto at gmail.com>
wrote:
Deleting the a project removes all the translated strings from translation
memory, so we should keep at least a few translated projects around even if
archived (only we can see it). Archiving the 3.16 is precisely to avoid
that some people keep translating it...
On Thu Mar 31, 2022, 10:40 AM GMT, DelazJ <delazj at gmail.com> wrote:
Well, wait! I just notice that we have a couple of languages (zh_hans, es)
that have translated the 3.16 docs since the switch. If someone can pull
the new strings to github[0] and open a PR/merge before we close the
project on Transifex, it could be nice for them.
[0] https://github.com/qgis/QGIS-Documentation/tree/release_3.16#translating
Le jeu. 31 mars 2022 à 12:34, DelazJ <delazj at gmail.com> a écrit :
> Hi Alexandre,
> Yes it could be a nice idea. Thanks.
> I wonder if we shouldn't simply remove 3.4 and 3.10 (and maybe 3.16)
> projects from Transifex. I can't see what we would need them for, we
> already pulled them in our repo. I thought translations suggestions in
> Transifex were picked from all projects, but checking differents strings,
> it seems they are fetched from the resources in the active project.
> So unless I'm mistaking, I will simply be in favor of removing those
> projects, freeing space and less confusion.
> Regards,
> Harrissou
> Le jeu. 31 mars 2022 à 11:53, Alexandre Neto <senhor.neto at gmail.com> a
> écrit :
>> Hi!
>> If no one opposes it, I will archive the QGIS 3.16 Documentation as it
>> will no longer be updated, right?
>> This avoids people translating its resources in vain.
>> Thanks,
>> Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20220331/6458eaaf/attachment.html>
More information about the Qgis-community-team mailing list
