[Qgis-community-team] Archive Documentation 3.16
DelazJ delazj at gmail.com
Thu Mar 31 05:07:11 PDT 2022
Hi Alex,
I'm not sure of translation memory being shared among projects. I finally
found https://docs.transifex.com/translation-memory/sharing-tm
Le jeu. 31 mars 2022 à 12:56, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> Deleting the a project removes all the translated strings from translation
> memory, so we should keep at least a few translated projects around even if
> archived (only we can see it). Archiving the 3.16 is precisely to avoid
> that some people keep translating it...
> On Thu Mar 31, 2022, 10:40 AM GMT, DelazJ <delazj at gmail.com> wrote:
> Well, wait! I just notice that we have a couple of languages (zh_hans, es)
> that have translated the 3.16 docs since the switch. If someone can pull
> the new strings to github[0] and open a PR/merge before we close the
> project on Transifex, it could be nice for them.
> [0]
> https://github.com/qgis/QGIS-Documentation/tree/release_3.16#translating
> Le jeu. 31 mars 2022 à 12:34, DelazJ <delazj at gmail.com> a écrit :
>> Hi Alexandre,
>> Yes it could be a nice idea. Thanks.
>> I wonder if we shouldn't simply remove 3.4 and 3.10 (and maybe 3.16)
>> projects from Transifex. I can't see what we would need them for, we
>> already pulled them in our repo. I thought translations suggestions in
>> Transifex were picked from all projects, but checking differents strings,
>> it seems they are fetched from the resources in the active project.
>> So unless I'm mistaking, I will simply be in favor of removing those
>> projects, freeing space and less confusion.
>> Regards,
>> Harrissou
>> Le jeu. 31 mars 2022 à 11:53, Alexandre Neto <senhor.neto at gmail.com> a
>> écrit :
>>> Hi!
>>> If no one opposes it, I will archive the QGIS 3.16 Documentation as it
>>> will no longer be updated, right?
>>> This avoids people translating its resources in vain.
>>> Thanks,
>>> Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20220331/44d656db/attachment-0001.html>
More information about the Qgis-community-team mailing list
