[Qgis-developer] qgis 0.8pre2 on suse10.2
Mike Leahy mgleahy at alumni.uwaterloo.ca
Wed Dec 20 10:05:21 EST 2006
Otto,
There is a patch posted on the developer list:
http://lists.qgis.org/pipermail/qgis-developer/2006-December/001218.html
This will let you compile QGIS 0.8 prerelease 2 with GEOS-3.0.0rc3 (but
not 2.x).  There's another patch for the SVN unstable branch that allows
compiling against either of 3.x/2.x in a follow-up message:
http://lists.qgis.org/pipermail/qgis-developer/2006-December/001227.html
I wouldn't say that these are officially approved patches, but it'll
probably do the trick for you.
The patches are renamed to *.bin files in the archive, but it's still
plain text, so I think you should be able to use them.
Regards,
Mike
Otto Dassau wrote:
> Hi,
> thanks for the hint, the devel packages were in /usr/include/Qt, so
> export QTDIR=/usr works.
> Now I have another problem. SuSe 10.2 unfortunately doesn't include GEOS, so I
> compiled and installed current GEOS-3.0.0rc3 and QGIS complains because it
> expects a GEOS 2.x.x Version.
> Where and what do I have to change to adapt the test? Or do I need to stick with
> GEOS 2.x.x?
>  thanks again
>   Otto
> On Tue, 19 Dec 2006 17:37:13 -0500
> Mike Leahy <mgleahy at alumni.uwaterloo.ca> wrote:
>> Hello Otto,
>> Look for an rpm called something like qt4-devel for your distribution -
>> the devel packages are what usually install the header files.
>> Mike
>> Otto Dassau wrote:
>>> Hi,
>>> I try to compile qgis pre2 on an opensuse 10.2 with qt4.2.1. QGIS doesn't
>>> find the header files like qglobal.h under /usr/lib/qt4/include. They don't
>>> exist and I don't know what further packages I need to install, because I
>>> thinkt I already installed all qt4 rpms that come with the distribution.
>>> Under download.qgis.org/qgis/ there is already a
>>> qgis-0.8.0_preview-1_no_grass.i586.rpm for suse 10. Was this package built
> using
>>> qt4 from suse or using compiled qt4 sources?
>>> Maybe someone knows a trick how to build the preview2 under suse 10.
>>> thanks a lot
>>>  Otto
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.qgis.org
>>> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
