[Qgis-developer] qt4 on 64bit
Tyler Mitchell tylermitchell at shaw.ca
Thu Oct 19 02:39:10 EDT 2006
On a similar note, now when I request GRASS support --with-grass=/my/path - QGIS configure fails because it looks for /my/path/lib64 - but grass created its folder /my/path/lib :)
I don't know how you handle these things in the make process, but for now I'll just symlink it :)
Thanks all,
Tyler
----- Original Message -----
Date: Wednesday, October 18, 2006 11:24 pm
Subject: [Qgis-developer] qt4 on 64bit
> Hi all,
> I'm trying to build qgis_unstable on fedora core 5, 64bit.  I got
> stuck for a while trying to get past Qt configure checks - and
> have finally got it.
> My libs are stored in /usr/lib64 and this is the 'standard' used
> in the latest qt4-devel rpm for my 64bit environment.  This seems
> to be the root my trouble.
> Two observations:
> 1) I got confused by needing to use --with-qtdir since qt4 doesn't
> install in the same way as qt3 in this environment.  It just puts
> everything in /usr/lib64 and /usr/include.  So I was forced to set
> --with-qtdir=/usr.  Can we change it so that it automatically
> checks there?
> 2) The configure check for lib vs lib64 is failing for some
> reason.  It is around line 19374 in configure or in the top of
> acinclude.m4:
> if test "`echo ${libdir} | sed -e  's#.*lib64.*#64#'`" = "64" ;
> then
>   _lib="lib64"
> else
>   _lib="lib"
> fi
> I don't know how to fix the test (or even test the test!) but when
> I forced it to use lib64, my configure actually worked:
> else
>   _lib="lib64"
> fi
> Hope we can find a better way to handle this - any suggestions?
> I'm glad to help out testing this.  Let me know if I forgot some
> vital information.
> Take care,
> Tyler
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
