[Qgis-developer] Updated Build Instructions for Ubuntu Dapper
Martin Dobias wonder.sk at gmail.com
Fri Sep 29 12:39:26 EDT 2006
Hi Tim,
just a small note to the instructions - regarding to build.sh script,
you need to use "debug" not "xdebug" as a parameter as the if command
in the script is:
if [ x$2 = xdebug ]
That 'x' in front of $2 is there because if $2 is empty, test command
doesn't have left operand and fails with an error. Prepending the
parameter with 'x' or something similar is common practise to preserve
compatibility with old shells, I guess that nowadays it's quite safe
to use 'newer' idiom:
if [ "$2" = debug ]
Looking further at build.sh, test for static builds is incorrect:
if [ x$2 = "static" ]
Martin
On 9/29/06, Tim Sutton <tim at linfiniti.com> wrote:
> Hi
> I maintain the Ubuntu Build Notes[1] for QGIS. Since I've just
> reformatted my hard drive, I took the opportunity to finalise the
> documentation for building QGIS 0.8 from source. I've split the old
> monolithic document into separate parts. The aforementioned link takes
> you to an index page which will grow over time as new versions of QGIS
> are created. Anyway I hope these  updated build notes for 0.8 [2] will
> help some of my fellow Ubunti-ites out there...
> [1] https://help.ubuntu.com/community/BuildingQuantumGisFromSource
> [2] https://help.ubuntu.com/community/BuildingQuantumGisPoint8FromSource
> Regards
> Tim
> Tim Sutton
> Visit http://qgis.org for a great Open Source GIS
> Home Page: http://linfiniti.com
> Skype: timlinux
> MSN: tim_bdworld at msn.com
> Yahoo: tim_bdworld at yahoo.com
> Jabber: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
