[Qgis-developer] grass plugin issue, #843
Otto Dassau otto.dassau at gmx.de
Tue Dec 4 04:18:52 EST 2007
Hi Jürgen, Horst and Leonardo,
Jürgen, I tested your fix for #843 in Revision: 7711 for public schema and it
works fine - thanks!
@Horst Düster and Leonardo Lami: can you also test to import PostGIS data with
schemas different from public into GRASS with the current qgis svn? Would be
great if this problem is fixed now.
kind regards,
 Otto
> Hi there,
> any opinions about http://svn.qgis.org/trac/ticket/843?   Should a
> static PostgreSQL dependency be introduced to the GRASS plugin?
> Jürgen
