[Qgis-developer] plugins installer
John C. Tull
john.tull at wildnevada.org
Fri Dec 28 22:50:32 EST 2007
Well, I just installed the geocoder plugin, so I am guessing that the
permission error is in the zip file for the BetterTabel plugin, but
this is only a guess.
John
> On Dec 28, 2007, at 7:46 PM, John C. Tull wrote:
>> Despite Paolo's followup comment about mkdir, and the fact that I
>> did the same a few weeks ago and installed the ImageMap plugin at
>> that time, I cannot install the BetterTable plugin (only one I
>> tried) now using most recent svn. I get the same permissions error
>> noted below. The double-slash should have no effect on this to my
>> knowledge. Any other ideas?
>> Cheers,
>> John
>> On Dec 16, 2007, at 9:50 AM, Paolo Cavallini wrote:
>>> Hi all.
>>> Testing the (very nice) python plugin installer (fresh qgis from
>>> svn), I
>>> get an error:
>>> Failed to unzip file to /home/paolo/.qgis//python/plugins ... check
>>> permissions
>>> Is this just a double slash problem? Any solution to this at the
>>> horizon?
>>> also, it would be good to use the same installer plugin to install
>>> also
>>> plugins from filesystem: is it feasible to add this feature?
>>> BTW: http://spatialserver.net:3001/ mention a bug (#781) which has
>>> been
>>> closed: better update the info?
>>> All the best.
>>> Paolo Cavallini, see: http://www.faunalia.it/pc
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.qgis.org
>>> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
