[Qgis-developer] 0.8.0: some comments/problems
Tim Sutton tim at linfiniti.com
Thu Feb 15 07:29:08 EST 2007
2007/2/15, Stephan Holl <stephan.holl at intevation.de>:
> Dear Qgissers,
> while working hard with the qgis 0.8.0 win32 binaries from
> download.qgis.org I found some oddities. Perhaps you are aware of them,
> if not I will create a bug-entry in the tracker:
> * Query-Build inside the metadata-tab does not open for PostGIS-layers.
>   It works on GNU/Linux though. Using the Querybuilder by
>   double-clicking the layername inside the open-dialog, everything
>   works fine though.
This is a known issue e.g. http://svn.qgis.org/trac/ticket/507
> * SPIT: once starting the import of a shapefile the 'cancel'-button
>   does not work anymore. It would be nice to cover the import into a
>   transaction block that 'cancel' could be easily rolled back.
Ok I think this needs a feature request filed so we dont forget it.
> * The OGR-driver where GRASS is linked against does not support
>   PostGIS. This should be changed so that GRASS can export to PostGIS
>   directly using v.out.ogr. (Is it save to exchange the gdal|ogr.dll
>   with one with postgresql-support, perhaps from fwtools for win32?!)
Ok good suggestion. We will need to rebuild gdal in the msys anyway
which I am planning to do for the 0.8.1 release so we can be using
gdal 1.4. I will try to build it with postgis support. I dont know if
its safe to use the one from fwtools - all I can suggest is to try
yourself and see if it works...
> The next 'problem' appear on both windows and linux-systems:
> * Snap-Distance for editing PostGIS-layers does somehow not work
>   correctly. Also 2 Error-boxes appear with the hint to the place to
>   change this.
I also had problems with this when trying to move vertices....another
one for the bug tracker.
> Some suggestion:
> * GRASS toolbox: The module-name should be prompted somewhere on the
>   tab, perhaps directly over the first entry-fields of the module-tab?
>   This would make it easier to see which module is open.
And one for the tracker!
> As always, thanks for your hard work on QGIS though.
We will address what we can in 0.8.1 and continue with 0.8.2 etc if needed.
> Best regards
>         Stephan
> Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
> Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
> Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
