[Qgis-developer] 0.9 Python modules on windows
Jesse Ayers jrayers at u.washington.edu
Mon Jul 30 14:15:22 EDT 2007
I should have mentioned that I tried copying the \qgis folder into
\site-packages as well, to no avail.
I did not compile 0.9 myself, I was using the compiled version provided by
Tisham in a post made on Sunday.  I just tried to download it again,
although both the NSIS installer and the zipped binary files appear to be
corrupt now.  I cannot install or unzip either file at this point.  Further
experimentation will probably have to wait until this evening when I get
home.
Thanks
--Jesse
>-----Original Message-----
>From: Aaron Racicot [mailto:aaronr at z-pulley.com]
>Sent: Monday, July 30, 2007 10:55 AM
>To: 'Jesse Ayers'; 'Luca Mandolesi'; qgis-developer at lists.qgis.org
>Subject: RE: [Qgis-developer] 0.9 Python modules on windows
>Hi there Jesse,
>So, I am not a cmake guru but if I remember:
>1) There is a variable in the ccmake setup that you can set
>called "BINDINGS_GLOBAL_INSTALL" which puts the core.pyd and
>gui.pyd files in your python site-packages directories... this
>is what I do so that there is not a need to find the libraries
>with PYTHONPATH.  On my machine the site-packages area with
>the correct files is at: C:\Python25\Lib\site-packages\qgis.
>Also just make sure the the WITH_BINDINGS:BOOL=ON is set in
>cmake as well... just to build the bindings at all!
>2) The path PYTHONPATH needs to be able to find the core.pyd
>and gui.pyd files and in my build install they are not
>there... so I can locate them in the build area (not install
>area) at C:\dev\cpp\qgis\build\python.  I have not tried to
>use them from their directly (as I have them installed in
>site-packages), but that is a place to start.
>Hope that helps!
>A
> Aaron Racicot - GIS Programmer
> 360.221.2441 - aaronr at ecotrust.org
> e c o t r u s t
> pobox 1614
> langley wa 98260
> www.ecotrust.org
>From: qgis-developer-bounces at lists.qgis.org
>[mailto:qgis-developer-bounces at lists.qgis.org] On Behalf Of Jesse Ayers
>Sent: Monday, July 30, 2007 10:25 AM
>To: 'Luca Mandolesi'; qgis-developer at lists.qgis.org
>Subject: Re: [Qgis-developer] 0.9 Python modules on windows
>No, I am not actually writing a script yet, just trying things
>out interactively.  The problem is that Python cannot find
>qgis.core and qgis.gui at all.
>My QGIS installation is at d:\qgis0.9preview1
>I have tried these 3 paths:
>d:\qgis0.9preview1
>d:\qgis0.9preview1\python
>d:\qgis0.9preview1\python\qgis
>In both the PATH and PYTHONPATH environment variables.  Is one
>of these paths or locations correct?
>Thanks in advance
>--Jesse
>>From: Luca Mandolesi [mailto:mandoluca at gmail.com]
>>Sent: Monday, July 30, 2007 9:49 AM
>>To: Jesse Ayers
>>> I get an import error, the specified module cannot be found.
>>Had you try to add to your script:
>>import sys
>>sys.path.append("your/qgis/path")
>_______________________________________________
>Qgis-developer mailing list
>Qgis-developer at lists.qgis.org
>http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
