[Qgis-developer] qgis.gui crash on mac os x 10.4
William Kyngesburye
woklist at kyngchaos.com
Wed Sep 12 10:03:52 EDT 2007
Gary, maybe this should be changed in the Qgis source? I imagine it
will affect other platforms where a user installs PyQt on their own
but uses a downloaded Qgis binary.
On Sep 12, 2007, at 5:05 AM, Luca Mandolesi wrote:
>>> Hmm, have you installed Qt and PyQt/SIP yourself? Which versions?
>>> Yes. I've installed Qt and PyQT tryin to build qgis svn. These
>>> are my versions:
>>> PyQt-mac-gpl-4.2.tar
>>> qt-mac-opensource-4.2.3
>> Even so, sys.path.append adds to the end of the search list, so the
>> Qgis bundle will be searched last, and your installed PyQt/SIP will
>> be found first. A better way might be to insert instead of append.
>> Try this instead of the sys.path.append:
>> sys.path.insert(1,'/Applications/qgis0.9.0.app/Contents/MacOS/share/
>> qgis/python')
>> This should put it at the beginning of the search list, but after the
>> script path (item 0).
>> qgis/python')
> Great! It was the problem!
> Now I can launch correctly the Martin Dobias tutorial!
> Thanks, thanks a lot!
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in
a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
