[Qgis-developer] qgis.gui crash on mac os x 10.4
Martin Dobias wonder.sk at gmail.com
Sat Sep 15 04:33:43 EDT 2007
Hi Wiliam,
I don't understand how do you mean this - what should be changed? If I
understand this issue correctly, the problem arises when someone adds
qgis bindings path to the end of python's sys.path list. Instead it
should be added to the start of the list... but how is this related to
the QGIS sources?
Regards
Martin
On 9/12/07, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Gary, maybe this should be changed in the Qgis source?  I imagine it
> will affect other platforms where a user installs PyQt on their own
> but uses a downloaded Qgis binary.
> On Sep 12, 2007, at 5:05 AM, Luca Mandolesi wrote:
> >>> Hmm, have you installed Qt and PyQt/SIP yourself?  Which versions?
> >>> Yes. I've installed Qt and PyQT tryin to build qgis svn. These
> >>> are my versions:
> >>> PyQt-mac-gpl-4.2.tar
> >>> qt-mac-opensource-4.2.3
> >> Even so, sys.path.append adds to the end of the search list, so the
> >> Qgis bundle will be searched last, and your installed PyQt/SIP will
> >> be found first.  A better way might be to insert instead of append.
> >> Try this instead of the sys.path.append:
> >> sys.path.insert(1,'/Applications/qgis0.9.0.app/Contents/MacOS/share/
> >> qgis/python')
> >> This should put it at the beginning of the search list, but after the
> >> script path (item 0).
> >> qgis/python')
> > Great! It was the problem!
> > Now I can launch correctly the Martin Dobias tutorial!
> > Thanks, thanks a lot!
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled
> with hyena offal?
> Second Pogril: I don't know.  Why IS life like sticking your head in
> a bucket filled with hyena offal?
> First Pogril: I don't know either.  Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
