[Qgis-developer] Re: srs.db epsg's added, shrinking?
Thu Apr 17 15:16:53 EDT 2008
Maciej Sieczka wrote:
> Tim Sutton pisze:
>> Gary and I originally loaded the srs.db using the postgis srs table.
>> The idea was to try to synchronise regularly against postgis srs table
> Tim,
> You mean the "tbl_srs", right? How were the "tbl_projection" and
> "tbl_ellipsoid" created?
> I'm trying to get srs.db/tbl_srs in sync with the spatial_ref_sys
> shipped with PostGIS 1.3.3 (should not be too hard) but I don't know
> what to do with the 2 other tables in srs.db.
Maciek,
Well, if you are doing that, should I belay efforts to have the
epsg_tr.py script generate stuff for the srs.db?  epsg_tr.py is
used to generate the postgis spatial_ref_sys table.
I'm not so keen that I want to duplicate efforts.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
