[Qgis-developer] Re: srs.db epsg's added, shrinking?
Maciej Sieczka tutey at o2.pl
Thu Apr 17 16:04:43 EDT 2008
Frank Warmerdam pisze:
> Maciej Sieczka wrote:
>> Tim Sutton pisze:
>>> Gary and I originally loaded the srs.db using the postgis srs table.
>>> The idea was to try to synchronise regularly against postgis srs table
>> You mean the "tbl_srs", right? How were the "tbl_projection" and
>> "tbl_ellipsoid" created?
>> I'm trying to get srs.db/tbl_srs in sync with the spatial_ref_sys
>> shipped with PostGIS 1.3.3 (should not be too hard) but I don't know
>> what to do with the 2 other tables in srs.db.
> Well, if you are doing that, should I belay efforts to have the
> epsg_tr.py script generate stuff for the srs.db?  epsg_tr.py is
> used to generate the postgis spatial_ref_sys table.
> I'm not so keen that I want to duplicate efforts.
Frank, All,
Before going on - I'm getting puzzled. Based on EPSG:2180:
PostGIS 1.3.3 (just released few days ago), their spatial_ref_sys table:
column 'proj4text column' : k = 0.999300
column 'srtext' : k = 0.9993
GDAL 1.5.0 + svn:
files pcs.csv, projop_wparm.csv, ecw_cs.wkt: k = 0.9993
PROJ 4.6.0, epsg file:
k = 0.9993000000000001
Shouldn't the number of zeros in '+k' be identical in all those software
in all places for them to interact smoothly? And why does the PROJ have
a bogus value? In 4.5.0 it was 0.999300.
I was going to trimm the spurios zeros from scale factor definitions in
QGIS srs.db (so that we get rid of the incompatibility as described in
this therad before [1]), but I'm now wondering whether fixing QGIS-GDAL
interaction this way would eg. brake QGIS-PostGIS or something else instead?
