[Qgis-developer] geos c api note
Jürgen E. Fischer jef at norbit.de
Thu Aug 14 15:18:30 EDT 2008
Hi Martin,
On Wed, 13. Aug 2008 at 17:05:44 +0530, Martin Dobias wrote:
> i'd like to say that in my opinion it would cause pain to switch to
> geos c api now before 1.0 release. there are more reasons:
> - we shouldn't force users to use some very new version of geos
Is that really a big issue?  We need tons of dependencies.  I don't
think using a current GEOS version is going to be a significant extra
effort for now, if someone is willing to go though the hassle of
building QGIS at all.
And in the long run using the C-API will enable us to use more
prepackaged binaries.
> - may bring new bugs
That's true for almost every change.
> - this is my biggest concern - we'd like to do many changes in
> geometry handling after 1.0 release and geos c api doesn't have
> support of many features that we will need so that might result in
> going back to geos c++ api.
Apparently the C++ API is not the recommended interface (see
http://download.osgeo.org/geos/doxygen/).  Note: on Windows there ure
only DLLs for the C-API.  Unless you use the static library there is no
available C++-API at all.
So I think we should target the C-API and extend it if necessary in
cooperation with the geos folks.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
