AW: [Qgis-developer] printing branch ready for testing
Hugentobler Marco marco.hugentobler at karto.baug.ethz.ch
Wed Aug 20 17:42:34 EDT 2008
Hi Tim,
I think most of the composer classes are reusable for plugins. Is your idea for the new quickprint plugin that it automatically places the items on the composer and user interacts with composer gui or that it directly prints to a pdf or similar format? I think both would be possible with the new composer code:
A plugin could create an instance of QgsComposition (that is a subclass of QGraphicsScene now). Then the plugin adds items programatically to the scene (e.g. QgsComposerMap, QgsComposerScaleBar, ...). Those items are separated from the configuration widgets now, so can be used also by plugins or even non-gui related code.
Then the plugin configures a paint device and a QPainter and calls QGraphicsScene::render to draw the map.
I think that even QgsComposer and QgsComposerView could be moved to gui such that plugins can use the composer gui.
So I suggest to move the following classes to core/composer:
QgsComposition
QgsComposerMap
QgsComposerPicture
QgsComposerLabel
QgsComposerScaleBar
QgsComposerLegend
and QgsComposer and QgsComposerView would go to gui.
In the QgisInterface class, there could be a method that returns a pointer to the composer of the current instance such that plugins could add their own buttons/item types.
But I must admit that I'm not familiar with the quickprint code and maybe there are some technical problems I didn't consider.
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: Tim Sutton [mailto:tim at linfiniti.com]
Gesendet: Mi 20.08.2008 23:16
An: Hugentobler  Marco
Cc: John C. Tull; qgis-developer at lists.osgeo.org
Betreff: Re: [Qgis-developer] printing branch ready for testing
Hi Marco
One thing I also wanted to ask - some time ago on this list we
discussed the mapcomposer overhaul and one of the ideas was to provide
a separate library component (to go into gui lib) and then a part in
app that makes use of this and handles user interaction. Is this still
possible? I would like to update the quickprint plugin to use your new
composer code but from basic looking through your changes I dont see a
way to do this without refactoring composer stuff. Failing that I will
probably try to repair it or remove it or disable it (since it has
been broken since render context stuff came into trunk I think). I
think there is still a strong usecase for having something like
quickprint where users basically press a button and get a print ready
map, so in an ideal world I'd like to not remove it. Do you have any
thoughts on the matter?
Best regards
Tim
2008/8/20 Hugentobler  Marco <marco.hugentobler at karto.baug.ethz.ch>:
> Hi John,
> I'm going to give it a try tomorrow on the old G4 in my office.
>>Is it possible, or planned, to be able to move map items to the
>>forward or backward? In other words, to be able to arrange map items
>>to bring them to the front of another item (drawn on top) or to place
>>them back in the draw queue. I hope that makes sense.
> Yes, this is one thing that I plan to implement before feature freeze.
> Regards,
> Marco
> Von: John C. Tull im Auftrag von John C. Tull
> Gesendet: Mi 20.08.2008 19:55
> Cc: qgis-developer at lists.osgeo.org
> On Aug 16, 2008, at 8:31 AM, Hugentobler Marco wrote:
>> Hi qgis devs,
>> The printcomposer branch is ready for testing now. The branch is
>> available with svn:
>> svn co https://svn.osgeo.org/qgis/branches/advanced_printing_branch
>> I'm going to compile windows binaries next week so that it is also
>> possible to test for non-developers. The plan is to merge the
>> printing branch to trunk prior to feature freeze for 1.0 (25. August).
>> Regards,
>> Marco
> Marco,
> John
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
