[Qgis-developer] QGIS 0.11.0 crashes when clicking on the projection-selector
Stephan Holl stephan.holl at intevation.de
Fri Aug 29 09:39:13 EDT 2008
Hello Stephan,
Stephan Holl <stephan.holl at intevation.de>, [20080829-08:51:02]:
> Hello QGISSers,
> while using the new RPM-packages for Suse I enconutered a crash (on
> SLE10) when hitting the projection-selector on the bottom right of the
> qgis-screen.
> The message is as follows, perhaps helpful for you:
> qgis: /usr/src/packages/BUILD/qgis-0.11.0/src/gui/qgsprojectionselector.cpp:610:
> void QgsProjectionSelector::applyProjList(QSet<QString>*): Zusicherung
> »rc == 0« nicht erfüllt.
> Does this has something to do with packaging or is this a more deeper
> problem (or even solved upstream)?
answering to myself....
This seems to be a problem with a too-old sqlite3-version. My maschines
runs sqlite3 3.2.8 which apparently does have a problem to read srs.db
What version of SQLite3 is at least required? 3.2.8 seems too old
though.
sqlite3 /usr/share/qgis/resources/srs.db
SQLite version 3.2.8
Enter ".help" for instructions
sqlite> .schema
Error: unsupported file format
sqlite>
Thanks for your help.
	Stephan
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080829/f261aa3e/signature.bin
