[Qgis-developer] cmake setup problems (windows)
marco.pasetti at alice.it marco.pasetti at alice.it
Mon Feb 4 04:42:12 EST 2008
I still have problems building qgis on windows; it's more than a week now, without any solutions! cmakesetup seems to find all dependencies:
C:\msys\local\src\qgis-0.9.1\build>cmake .
-- Found Proj: c:/msys/local/lib/libproj.dll
-- Found Sqlite3: c:/msys/local/lib/sqlite3.dll
-- Found GEOS: c:/msys/local/lib/libgeos.dll.a
-- Found GDAL: c:/msys/local/lib/libgdal.dll
-- Found PostgreSQL: c:/msys/local/bin/libpq.dll
-- Found Expat: c:/msys/local/lib/libexpat.dll.a
-- Using GSL from
-- Found GRASS: c:/msys/local/grass-6.3.0RC4 (6.3.0RC4)
-- Python libraries found
-- Python bindings enabled
-- Found Qt-Version 4.3.3
-- Configuring done
-- Generating done
-- Build files have been written to: C:/msys/local/src/qgis-0.9.1/build
but when i make and install, and then try to launch qgis, it reports the following error:
procedure entry point X509_STORE_set_flags could not be located in the dynamic link library libeay32.dll
I tryed to check qgis.exe with dependencies walker, and it reports some errors, but I don't know why.
With cmakesetup I have the following blank entries:
CMAKE_EXE_LINKER_FLAGS_*
CMAKE_MODULE_LINKER_FLAGS_*
CMAKE_SHARED_LINKER_FLAGS_*
EXECUTABLE_OUTPUT_PATH
LIBRARY_OUPUT_PATH
and it doesn't find QT_QTNSPLUGIN
all the rest seems to be OK.
Thank you for your support,
Marco
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080204/b8cc99ea/attachment.html
