[Qgis-developer] Re: composer redesign branch
Paolo Cavallini cavallini at faunalia.it
Wed Feb 13 02:17:38 EST 2008
Tim Sutton ha scritto:
> There is already a feature spec on the wiki.
> http://wiki.qgis.org/qgiswiki/Features_For_QGIS_Version_1.0
> The spec should probably be revised at our next dev meeting as some
> things are probably no longer on the table.
I think this is very much true. One thing that I believe it is very
important is proper labelling, with collision detection, angle_follow,
etc. Speed is becoming important, as noted, as well as stability (avoid
crashing). Also thematic mapping has scope for improvement.
I guess it's all on the wishes (on the trac), but it should be properly
prioritized.
To me, geoprocessing is far less important, as this can be easily done
with grass.
All the best.
pc
Paolo Cavallini, see: http://www.faunalia.it/pc
